Old 12-19-2010, 04:49 PM   #1
Installing an additional ground rod - power off?
The previous owners used the old water line as the ground rod, but that line was replaced with pex. I only have a couple feet of metal in the earth right now.
I bought a 8' copper rod and installed 2' from the side of my house. I have the copper wire (about a 1/4" thick) run to the pole, but have not connected it to the existing copper line going to the old water line.
Do I need to power shut the breaker to the house before touching the existing ground wire?
sheslostcontrol is offline   Reply With Quote
Old 12-19-2010, 05:02 PM   #2
joed's Avatar
Not if you are careful. Depends how confident you are about not shorting to the main power wires. You need to connect this new ground direct to the panel. The old wire now becomes a BOND to the water lines.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-19-2010, 06:18 PM   #3
Couple more questions..
Can I attach the new ground line to the existing (but cut) ground line with a copper clamp?
Also what do you mean by bond? If the old line is cut (above) it won't matter anymore right?
Old 12-19-2010, 07:09 PM   #4
joed's Avatar
The old line has to remain. You need them both.
Old 12-20-2010, 08:44 AM   #5
A bond is an essentially resistance free electrical connection, accomplished either by having the two metal items in question fastened directly to each other or connected to opposite ends of a piece of wire or to some other intervening metal object.
What I was told that where there is a ground rod, the wire from it to the panel must be continuous. If the ground wire to the water pipe is added later it may terminate with a clamp at the ground wire to the rod. If there was no ground rod then the wire from the panel to the water pipe must have been continuous.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
strange electric problem in new house, hot ground! area123 Electrical 29 07-25-2010 12:29 PM
Installing siding and city power junction/connector rugby style Building & Construction 5 07-12-2010 12:13 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Installing 20 amp circuits in metal boxes, is 14 ga OK for ground pigtails? thegonagle Electrical 17 11-14-2008 08:34 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
