Installing A 3 Way Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 09:42 PM   #1
Question
Installing a 3 way timer switch
I purchased a GE Sunsmart Digital Timer # 15312 to replace an old Intermatic model. The problem is: The Intermatic has 1. black 2. blue 3. red & 4. the green which I know is the ground.
The new switch from GE has:1. black 2. blue 3. red 4. white and 5. the green/ground.
As far as line/load, the box has only 1 set of wires entering/leaving the box. So, does this mean that this is the load side or line side?
AND, would the white & blue wires hook up to the incoming white wire? This threw me for a loop, Thanks in advance,
spark0fun is offline   Reply With Quote
Old 02-26-2013, 10:41 PM   #2
The new digital timers require a neutral to work so the extra wire (white) is for the neutral. In your configuration you probably don't have a neutral in that box. See what the wiring instructions say about that. I assume you have 3 wires (black, red and white) and possibly a ground wire in that box.
clydesdale is offline   Reply With Quote
Old 02-26-2013, 11:38 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Here the installment instruction and that timer do requried a netural to order to get that timer function otherwise without a netural the timer will not function at all.
Here the PDF file.
GE timer 15312
Take a second look at the switch box again and count how many conductor you have actually inside the switch box and what colours it is.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
clydesdale (02-26-2013)
Tags
3way , timer switch
Installing Switch In Reversing AC Motor RetiredLE Electrical 18 10-26-2014 10:51 PM
Installing 3 Way Sunsmart Digital Timer Rich Kramer Electrical 7 12-03-2012 02:06 PM
Timer switch at end of run tmaher Electrical 3 05-16-2011 06:06 AM
GE Smart Timer in a 3 way switch vanisle Electrical 8 10-27-2010 12:34 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
