-   -   Installing a 3 way timer switch (http://www.diychatroom.com/f18/installing-3-way-timer-switch-173082/)
spark0fun 02-26-2013 09:42 PM
I purchased a GE Sunsmart Digital Timer # 15312 to replace an old Intermatic model. The problem is: The Intermatic has 1. black 2. blue 3. red & 4. the green which I know is the ground.
The new switch from GE has:1. black 2. blue 3. red 4. white and 5. the green/ground.
As far as line/load, the box has only 1 set of wires entering/leaving the box. So, does this mean that this is the load side or line side?
AND, would the white & blue wires hook up to the incoming white wire? This threw me for a loop, Thanks in advance, :eek:
clydesdale 02-26-2013 10:41 PM
The new digital timers require a neutral to work so the extra wire (white) is for the neutral. In your configuration you probably don't have a neutral in that box. See what the wiring instructions say about that. I assume you have 3 wires (black, red and white) and possibly a ground wire in that box.
frenchelectrican 02-26-2013 11:38 PM
Here the installment instruction and that timer do requried a netural to order to get that timer function otherwise without a netural the timer will not function at all.
Here the PDF file.
GE timer 15312
Take a second look at the switch box again and count how many conductor you have actually inside the switch box and what colours it is.
Merci,
Marc
