Installing 3-way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2005, 11:45 AM   #1
Question
installing 3-way switches
In our basement we're finishing, the living area has 2 lights on a 15 amp circuit and are the only things on the circuit. There's 14-2w/g going from the panel to the light switch (which is on the opposite side of the room.) I want to replace it with a 3-way and put a 3-way swicth at the entrance of the room. My first question is: Since it's a 15 amp circuit 14 gauge wire can I use 12 gauge (because I have some already) to continue the wiring for the new switch or change it all to 12gauge? 2nd, do I still use 2 wire w/g? And how do I wire these switches?
AllMyFault is offline   Reply With Quote
Old 03-20-2005, 02:54 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 482
You need 14/3 or 12/3 w groound to complete this job. Leave the power where it enters your current switch, tak a peice of 14/3 and run it to your new switch location, wire the switch with the white wire on the common screw, remark it with a peice of black tape, at you current switch, takt the black on the power in, tie it to the common screw on your 3 way switch. tie the white wire from your 3 wire to the black wire going to your light and hook the black and red leftover to either of the remaining screws on both 3 way switchs. Make sure you turn of the breaker first. If you have anymore questions, just ask
Old 03-20-2005, 09:17 PM   #3
I understand, thank you, but which is the "common" screw on the 3-way switch?
Old 03-20-2005, 09:20 PM   #4
ryaniniowa's Avatar
on most there are 2 at the top across from each other and one at the bottom. It's the one by itself on the bottom. usually it's a different color also.
Last edited by ryaniniowa; 03-20-2005 at 09:57 PM. Reason: I thought I didn't make sense.
ryaniniowa is offline   Reply With Quote
Old 03-20-2005, 09:34 PM   #5
Originally Posted by ryaniniowa
on most there are 2 at the top and one at the bottom. It's the one by itself. usually it's a different color also.
Thanks I'll work on it tomorrow and let you guys know.
Old 04-06-2005, 10:42 AM   #6
reducing light switches from 2 to a single switch only
lesley buck is offline   Reply With Quote
Old 04-06-2005, 11:54 AM   #7
jbfan's Avatar
Rewards Points: 482
is that a question?
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
Where to buy paddle light switches in bulk? Proulx06 Electrical 3 05-21-2007 06:43 AM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 10:26 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
