Installing 3 Way Sunsmart Digital Timer
I've installed the timer following the diagram; it has constant power and manually works to turn the lights on and off. I wired the second switch with the jumper as shown in the diagram but cannot make the second switch work properly.
Without the jumper in place, the switch works to turn on the lights after 3 or 4 trips. The lights come on and then go off; following two or three trips of the switch the lights stay on. If the lights are turned on at the timer they come on and off manually as expected and the the second switch can turn them off with no issues. I did wire the jumper into the second switch as shown on the diagram but it disables the switch (tripping won't turn the light on or off). It appears that the jumper is intended to eliminate one of the travelers allowing the time to control the circuit but I don't fully understand the purpose of the jumper. I want to be able to turn the light on and off at the front door but expect that the timer will control the lighting most of the time. This circuit is for the outside lights with a switch in the garage and by the front door. I wired the timer in the garage leaving the larger on/ off switch in the hall way. Garage is also where the circuit breaker box is located. Any help / advice is appreciated Rich |
If you post a link to the timer and tell exactly how you wired the switches and the light then we might be able to tell where the problem is.
Digital timer
Timer switch wired as follows: green to ground, white to the neutrals in the box, blue to the hot power source, the remaining wires to the original travelers. At the remaining wall switch, I used the jumper to connect the switch hot lead to the hot line and one of the travelers (disconnected from the switch as described in the instructions. Digital switch can be used manually and the timer works to turn lights on (not off) IF the the switch is left in the off position and the timer left on auto
What is the make and model of the timer?
GE SunSmart digital timer. Just purchased at Home Depot
GE SunSmart digital timer is a line of timers. You need to supply a specific model number.
GE Sunsmart digital timer - model # 15312
Blue goes to your load. It is the switched hot to the load. Here is the online instal instructions. http://www.jascoproducts.com/support...de-eng-spa.pdf |
| All times are GMT -4. The time now is 10:17 AM. |
