Installing 240V Baseboard Heater And Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 03:23 PM   #1
Installing 240V baseboard heater and thermostat
I live in Virginia which is either 110 or 120 current (?). I'm getting a cadet baseboard heater. To get a matching thermostat I need to go to the 240 V model. I'm told by home depot that I can plug that into my standard household socket? Does that sound right?
rdavidschm is offline   Reply With Quote
Old 03-26-2011, 05:11 PM   #2
I=E/R
a7ecorsair's Avatar
Your house power is 240 Volts. Do you have an electric range, electric dryer, or air conditioning? If so, look in your breaker box and you should see a breaker with a tie bar or a double wide breaker with a single lever. Those are 240 volt breakers.
What size Cadet are you putting in?
a7ecorsair is offline   Reply With Quote
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 07:30 AM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 08:03 PM
Help move baseboard heater thermostat and avoid electrocution Gunserotti Electrical 28 01-04-2009 04:48 PM
