Installing 230V Outlet - Chicago - Code - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 06:54 PM   #1
Alrighty. I'm planning on getting this welder:
http://www.millerwelds.com/pdf/spec_sheets/AD1-5.pdf
It has a 6-50P plug on the end. I want to simply install an outlet for it right under my breaker box. Called a local electrician, he quoted me as $350 to do the job. Seems quite high to me as all I'll need is about 6" of unbent conduit run from my box. I'm planning on installing it myself, now. I just want to get some info from the experts so that I keep it up to Chicago code to keep my landylord happy.
OK, here we go with my plan. I have done a lot of internet reading on the process, but I'm going to keep this really dumbed down so I don't get ahead of myself. Let me know how I'm doing so far.
I'm going to buy this outlet:
http://www.homedepot.com/Electrical-...atalogId=10053
This box:
A piece of 1/2" conduit:
Two connectors (one for each end of the conduit going into the box and breakerbox):
This breaker:
I plan on making a ~50' 8/3 extension cord to get from the outlet to my welder.
Questions:
  1. Does this all sound "correct" at this point?
  2. What gauge wire do I want to run from the breaker, through the conduit, to the outlet?
  3. Since the welder only requires a max of 25a, would I be wiser to install a 30a breaker so I could use a ligher wire on the extension cord?
Thanks!
Adam
OakBehringer is offline   Reply With Quote
Old 07-13-2011, 07:11 PM   #2
I=E/R
a7ecorsair's Avatar
Deleted
a7ecorsair is offline   Reply With Quote
Old 07-13-2011, 07:16 PM   #3
Rewards Points: 1,016
Nice welder - what you going to be doing with TIG? I have a Miller 180 MIG setup. I operate mine on a 30a circuit using #10 wire - and a 35' extension cord of #8 SOOW.
Has the landlord approve of this addition - and you doing the addition? As a landlord, I would have a problem with a tenant making any such addition.
____________
Vince
Old 07-13-2011, 07:23 PM   #4
Sparky
Rewards Points: 510
there is absolutely no way you'll ever get a 50 amp outlet in a handybox
you need one of these.
and one of these
i would run 2 #6 THHN Copper hots(any color but white) and a #10 THHN Copper Ground(must be green)
if you wanted to run a 30 amp breaker, all 3 wires could be #10(2 hots 1 ground)
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
OakBehringer (07-13-2011)
Old 07-13-2011, 07:23 PM   #5
Mostly light hobby fabrication for handbuilt motorcycle parts. I am going to talk to my landlord before proceeding, just getting all my ducks in a row before I do.
Old 07-13-2011, 07:29 PM   #6
and one of these
Roger that - 6ga for 50a, 10ga for 30... and the larger box.
Thanks,
Adam
Installing 120VAC Outlet DK75 Electrical 4 11-26-2007 03:51 PM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 05:32 PM
Installing a 230v outlet ThePlumber Electrical 7 07-15-2006 10:16 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
