Hi Guys,
Need some expertise on how to go about installing a 220V outlet in the garage to run a Lincoln 225/125 welder I am thinking of buying. Also as the garage currently only has one plug for the garage door opener I would like to have room to add two more 110v plugs and another 220/240v for an air compressor down the road.
The main service panel is in the basement and the garage is on the other side of a 1950 ranch style house. I am still planning just how I am going to run the wire (e.g up throu wall and into attic and into garage, out basement wall and run conduit to garage following eaves). I am still working on this but I am comfortable runing/fishing the wire once I figure out the run. I will be hiring an electrican for the hook-ups but before I contact an electrician I want to understand the different options.
I have taken a picture of the meter outside the house, which looks like 200a service.
I have also taken pictures of the service panel downstairs, it is an older federal pacific panel. The sticker mentions "Mains 100amp max". The main on/off switch states 100A so I guessing this is a 100a service panel.
Now I am looking at the most economical way of getting power to the garage for the welder and also enough headroom to put in other plugs in the garage. The wife and I are only planning on staying here for about five years so don't want to throw alot of money at it but at the same time for the next five years want to have a garage where I can work on stuff.
Please note I have limited electrical experince and I would only run the wires to help save some money, the electrcian would do the hook ups and rest of the install just afriad if I call someone right now they are going to quote somehting extremely high if I don't research it.
So guys what would everyone suggest I do???? Here are my ideas to toss around but not sure if feasible or not!
1.) Install a seperate 100A panel after the main meter. Thou not sure on what would be needed to do this.
2.) Install a sub-panel from the main service panel either in the garage or near the main panel. Not sure what size sub-panel can be pulled from the current main panel.
3.) Rip out the current 100a panel and have installed a 200 amp panel. But do I still need some sort sub-panel in the garage so I only need to fish one run of wires to the garage and distribute from the sub panel.
In a nutshell looking for the cheapest route but still haev capabilities of adding other things easily in the garage down the road as I need them.
Thanks for all the help guys, look forward to everyones idea.
