-   -   installing 200 amp panel (http://www.diychatroom.com/f18/installing-200-amp-panel-82161/)
dgaulin 09-23-2010 02:11 PM
I recently installed a combination meter panel/shutoff at a construction site with an outlet so the contractors had power. Everything was done correctly....passed inspection. Now that the house is shelled in, the contractor wants me to install the 200 amp panel in the basement so we can start wiring the house. He ran the 200 amp wire through conduit into the basement. I know need to hook up both ends. The main service entrance in the basement and also attach the 200 amp wire to the meter/breaker box outside. Along with the 200 amp three wire, he also ran a separate ground wire. Correct me if I'm wrong, but I don't need a ground wire running from the shutoff/meter panel outside into the main panel in the basement. I already grounded the meter/shutoff panel which is about 50 feet from the house. Obviously, I will ground the main service entrance with two grounding rods, so that will be grounded on it's own.
This is the first time I have installed a service entrance where there is already a shutoff between the meter and the service panel. Is there any differences in terms of installing the service entrance because of that? Do I make any changes to the neutral and grounding bars? Do I keep the neutrals isolated from the grounds?
Doug
frenchelectrican 09-23-2010 02:25 PM
The meter main combo box is that meter unit will be pretty much permament there ?
If so you will have no issue as long you follow the NEC code on this one.
Any thing after the main breaker at the meter socket locaton all the 120/240 volt circuits must use 4 conductor the code no longer allowed 3 conductor set up so you will denfinetly need two hot conductors 1 netural and 1 ground conductor.
What size conductor you have there ?? and type as well,.
All the breaker boxes you will be installing you have to treat them as subpanels not the main panel rules so that mean you have to keep the neutral and ground conductor seperated at the inside breaker box and of course you will have to buy couple ground bussbar and keep the netural bussbar insolaited { do not use the bonding screw or bonding jumper }
As long you have proper wiring permits you should be fine and you doing all the wiring yourself or have someone doing this for ya ??
At the main meter socket location yeah you will need two ground rods at that location and also at the house as well you will need to sink two more ground rods at the house breaker panel.
And for ground rod conductor you will need 16mm˛ {#6 AWG } unless your inspector requred 25mm˛ {#4 AWG } I will just go with latter and be done with it.
I know you may have more question to come up just ask us we can fill you in more details along the way.
Merci.
Marc
nap 09-23-2010 03:26 PM
edited to ensure I do not aid an illegal act
Speedy Petey 09-23-2010 03:32 PM
Originally Posted by nap (Post 506134)
Is this your house?
I agree with this question.
If this is not your house, and you have to come here and ask these questions, you should NOT be doing this work as a job for pay.:no:
a7ecorsair 09-23-2010 03:42 PM
Yup, and what about this:
And, you can't heat the panel until the inspection is done:huh:
dgaulin 09-23-2010 03:50 PM
I am not doing it for pay, not that it's any of your business there Speedy Pete. The information on not needing the ground between the shutoff and the service panel was told to me by the local inspector, so I assumed what he was talking about is valid. I already knew that I need to isolate the ground in the main panel because the main panel is now a sub-panel. By the way, you don't have to be licensed in New York to work in the electrical business.
a7ecorsair 09-23-2010 03:57 PM
In this meter panel you refer to, is there 200 amp breaker or is it a disconnect switch?
dgaulin 09-23-2010 04:05 PM
It is an all-in-one with a 200 amp breaker.
nap 09-23-2010 04:34 PM
actually, it is our business. It is illegal in almost every state for a person to work on a house that is not their primary residence unless they are licensed as a contractor or an electrician. I doubt NY is any different in intent.
since the local yokels seem to be willing to give you directions (even incorrect direction), I'll leave it with what I have given already.
dgaulin 09-23-2010 04:56 PM
Nope. No license needed in NY. Plumbing yes, electrical no. You only need to get a permit from the municipality that you are working in. And yes, I am a licensed contractor in NY.
dgaulin 09-23-2010 05:12 PM
And by the way, you guys must be bored if all you do is sit around busting people's chops on a chat board. God forbid you just answer the question and give a little help to someone.
nap 09-23-2010 05:35 PM
we simply do not want to help a person break the law, or even worse, injure or kill somebody.
and now you claim to be a contractor yet you aren't getting paid for this. Things that make you go hhmmm.
many individual municipalities require an electricians license. I'll err on the side of caution.
a pro should have the resources available to them without having to resort to a DIY forum. That is a sign you should not be doing what you are.
Oh, and to your claims:
From: "dos.sm.InetLcns" <InetLcns @ dos.state.ny.us>
Subject: RE: Does NY State License Plumbers, Electricians, or other skilled trades?
Thank you for your email.
Please be advised there is not a state license required in order to work
as a plumber, electrician, or contractor. These individuals are
registered within the county in which they do business. You will need
to contact the local government such as the county, village.
dgaulin 09-23-2010 05:48 PM
Well, I'll be signing off now. I need to go enjoy my house on the lake. You can continue existing in your cynical life browsing the chat boards and working as a lackey for your local residential rlectrical contractor. Bye bye now.
Jim F 09-23-2010 06:43 PM
What county in NY do you do electrical work in so I don't inadvertently hire you to do my electrical work.
Speedy Petey 09-23-2010 07:47 PM
Yup. Another typical f-ing NY hack GC/carpenter who thinks electric is no big deal so they'll do it themselves and make the $$ that the real electrician would have made. :mad:
I agree, if you were ANY sort of a professional you would NOT be coming to DIY message boards learning how to do a trade.
I deal with hacks like you all the time buddy. Usually it is fixing the screw ups that you pull. I do charge more for that BTW, and that is not sneaky. :thumbsup:
