Installing 20 Amp Circuits In Metal Boxes, Is 14 Ga OK For Ground Pigtails? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 07:45 PM   #1
Installing 20 amp circuits in metal boxes, what ga. ground pigtails? (and 2 more Q's)
I'm in the process of rewiring my garage. (Basically, I'm at the rough-in stage, but it will go quickly after I get the boxes mounted and the cables stapled.)
Main question: I'm using all 12 ga wiring so that I can run 20 amp breakers. I'm also using metal boxes, which obviously need to be grounded. I bought a baggie of pre-made ground pigtails for that purpose, but it turns out they're 14 ga. Is it acceptable for the ground connection on the metal box to be 14 ga, or should I scrap those and use 12 ga exclusively?
Second question: I got a good deal on some ceiling boxes for the lighting (planning to use 4 of them for some basic ceramic light fixtures), but they don't have any mounting brackets built in. Can I just mount them directly to the underside of the ceiling joists with wood screws, or could that become a fire hazard? (I'll be using screw-in CFLs, but you never know if some future homeowner or renter might put 150-200 watt incandescents in there, so I'm a little concerned about the potential heat.)
EDIT--Third Quick Question: can I double up the NM cable under the staples (each staple securing two cables), or should I run two cables side-by-side?
Thanks!
thegonagle is offline   Reply With Quote
Old 11-13-2008, 08:25 PM   #2
DIYer
You can't use a 14 gauge ground with 12 gauge wires, unless the breaker is 15 amps.
You aren't supposed to. It's a pretty minor issue though. If you want to save time get the extra wide staples and you can do two at once side by side.
Gigs is offline   Reply With Quote
Old 11-13-2008, 08:27 PM   #3
Electrician
Why not? My staples are listed for such use.
chris75 is offline   Reply With Quote
Old 11-13-2008, 08:27 PM   #4
DIYer
I read somewhere you weren't supposed to stack NM under staples. Maybe what I read was wrong.
Old 11-13-2008, 08:28 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Most staples are Chris, not just yours.
Old 11-13-2008, 08:29 PM   #6
Electrician
Dont know what you read, but Briscon staples allow multiple wires under one staple. You cannot staple wires on edge, but thats the only nec issue.
Old 11-13-2008, 08:29 PM   #7
I read somewhere ...........
Famous last words.
Old 11-13-2008, 08:30 PM   #8
DIYer
Originally Posted by Speedy Petey View Post
Famous last words.
You got that right. I defer to you guys.
Old 11-13-2008, 08:30 PM   #9
Electrician
I'm sure, but not all staples are created equal.
Old 11-13-2008, 08:32 PM   #10
Oh I know. I was just bustin'.
I have seen some rated for three cables.
Old 11-13-2008, 08:33 PM   #11
Electrician
I know you were.
Old 11-13-2008, 08:34 PM   #12
DIYer
You all should answer his other question because I'm kind of curious too. I think it would be ok but I wasn't sure enough to say that. (The one about the light boxes)
Old 11-13-2008, 08:38 PM   #13
Well, you need to use 12 awg, all metal boxes need to be bonded to the ground, you can stack romex with the connectors if they are rated for such.
You NEED an electrical box for the lights, or do you mean installing the box to the bottom of the joist? I dont think there is anything wrong with that.
rgsgww is offline   Reply With Quote
Old 11-13-2008, 08:43 PM   #14
OK, I'll scrap the 14 ga. pigtails, and I'll double check that my staples are approved for two cables before I try that trick. (I got the idea to double up the cables because the previous homeowner, supposedly a general contractor, did that in several places when he re-wired the main house, but I just wanted to be sure it's OK.)
What about the ceiling boxes? (I believe they're called octagon boxes; indeed they're approximately octagonal in shape.) I can just shoot 'em up there to the bottom of the joists with wood screws, right?
Note: it's an unfinished, detached garage, and I have no plans to drywall, so having them stick out too far from the bottom of the joist is no concern to me.
(EDIT: Of course I'm using boxes for the light fixtures! Sorry, I'm not always the clearest writer.)
Old 11-13-2008, 08:57 PM   #15
I often see 14 for gnd pigtails. Not code compliant though. It makes the recep a bit more manageable. Actually, one inspector recently OK'd it.
I often put two/three cables under a staple. After several thousand staples, it's never been an issue.
Install the ceiling boxes on the side of the joist so your fixture will mount flush to the bottoms of the joists.
Can't use NM cable in unfinished garages here.
220/221 is offline   Reply With Quote
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
plastic or metal boxes for outlet wiring? yummy mummy Building & Construction 9 12-31-2006 01:37 PM
Plastic vs metal switch boxes tropic home Electrical 1 11-29-2006 05:54 PM
