Installing 120VAC Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 03:03 PM   #1
Rewards Points: 87
This may be a simple one to answer. I have an outlet box in a bedroom with a cover. After removing the cover I noticed there is a red and a white wire in there just taped off...connected to nothing. I was curious if one was hot and the other neutral, could I connect a standard wall outlet in here and use it for a lamp/tv/etc.????
I haven't tried it yet, however I have a multimeter which I can check to see if there is power here. I can try that later today.
DK75 is offline   Reply With Quote
Old 11-26-2007, 03:09 PM   #2
So the red and white are not tied together just in there taped off? Is there any switched plugs in your room? When you go to check for voltage see if the voltage is dependant on a switch.
RichyL is offline   Reply With Quote
Old 11-26-2007, 04:14 PM   #3
Electrician philosopher
If I am not mistaken, everything in Chicagoland is in pipe, no romex. So perhaps the color shouldn't get the consideration it would if it were wired in romex. The only way to check is with the meter.
Andy
Andy in ATL is offline   Reply With Quote
Old 11-26-2007, 04:28 PM   #4
Rewards Points: 87
I believe you are correct, romex is not approved per Chicago code. The hard conduit coming into the outlet box has only the red and white wire coming in. The end of the wires have electrical tape on them and that is it.
When I did the ceiling fan in this room, I noticed there was also a yellow wire in the ceiling junction box. I determined this led to another wall outlet that was wired to one of the two wall switches. Luckily I was able to break this wire in the ceiling box and use it for the ceiling fan. Now I have the fan motor and lights each wired to the two switches on the wall. No need for a switched outlet in this room.
I am goign to meter the wires and see if I have good power there. I will post my findings later. Thanks
Old 11-26-2007, 04:51 PM   #5
joed's Avatar
Rewards Points: 12,028
Could be anything. You need to find the other end of the iwres. You need to measure the voltage on the wires.
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 06:32 PM
Installing a 230v outlet ThePlumber Electrical 7 07-15-2006 11:16 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
