Old 01-08-2013, 11:35 PM   #16
Installed a Transfer Switch... Will this pass code ???
That is an easy fix. Put reducing washers a.k.a. chinese money in there to cover up the chewed up part.
Auger01 is offline   Reply With Quote
Old 01-22-2013, 10:03 PM   #17
Hey Everyone.....
I would like to thanks kbsparky especially for suggesting the octagon blank plate. I finally got around to making the modifications to my mess. I purchased a nice hole saw set to make a perfect cut. I should have done that in the first place, well you cant cry over spilt milk...
Ok.. So here are some pics of the fix... let me know what you think.
Installed a Transfer Switch... Will this pass code ???-photo-2-.jpg   Installed a Transfer Switch... Will this pass code ???-photo-1-.jpg   Installed a Transfer Switch... Will this pass code ???-photo.jpg   Installed a Transfer Switch... Will this pass code ???-photo-3-.jpg
Durkis007 is offline   Reply With Quote
The Following User Says Thank You to Durkis007 For This Useful Post:
kbsparky (01-23-2013)
Old 01-22-2013, 10:05 PM   #18
Licensed Electrician
k_buz's Avatar
Much better, but the locknuts are on backwards.
Location...Location...Location
The Following User Says Thank You to k_buz For This Useful Post:
NJMarine (01-23-2013)
Old 01-22-2013, 10:10 PM   #19
Thanks KBuz.... Will make that change before I do the wiring.
Old 01-22-2013, 11:00 PM   #20
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Looks great once you switch the lock nuts like kbuz said. Everyone makes mistakes and we never stop learning. Hopefully you will post some pictures when you are done.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-23-2013, 03:31 AM   #21
kbsparky's Avatar
Originally Posted by Durkis007 View Post
Hey Everyone.....
Yup, now things are looking MUCH better!
I won't mention those lockrings, since others have already done so ....
Background:
I do a lot of mobile/modular homes. Many times, when we arrive to make the hookup, we will discover the main conduit the hangs under the house was pushed UP into the panel. This condition resulted in the concentric knockouts being separated, and often times the entire bottom of the panel was bent up, etc.
We would have to hammer the bottom of the panel enclosure back down, and then use an octagon plate to "repair" the now too-large opening where the conduit terminates.
The end result is similar to your completed repairs.
-KB
Old 01-26-2013, 11:45 PM   #22
deverson's Avatar
Not sure if you have locknuts on the outside of those boxes but you may want to install a grounding bushing on one side.
deverson is offline   Reply With Quote
Generac 10KW generator and Generac RTS12EZA1 transfer switch. exhdo1 Electrical 8 11-30-2011 03:33 PM
generator transfer switch chuck172 Electrical 8 06-30-2011 04:34 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 08:45 PM
