Old 01-05-2013, 12:34 AM   #1
Installed a Transfer Switch... Will this pass code ???
Hi All..
Ive read the forum for a while. But this will be my first post.
With the recent passing of sandy, and having electrical cords all over the place with the generator, I decided to install a transfer switch. I tried to get a professional in, but could only get one guy to actually show let alone give a call back and he wanted 1200 for the labor !!
Anyways... So far I flush mounted the Gen-Tran switch next to the service panel. I initially thought the knock outs on the two panels would line up, but they didn't. I fear that I created a problem that wont pass inspection.
As you can see in the photos I ran a piece of conduit through the stud between the two panels, but its not pretty.
I did apply for a permit with the building department, so this will be inspected.
Installed a Transfer Switch... Will this pass code ???-photo.jpg   Installed a Transfer Switch... Will this pass code ???-photo-2.jpg   Installed a Transfer Switch... Will this pass code ???-photo-3.jpg
Durkis007 is offline   Reply With Quote
Old 01-05-2013, 01:55 AM   #2
my gut says no. but i am no electrician
redman88 is offline   Reply With Quote
Old 01-05-2013, 04:11 AM   #3
Electrical Contractor
kbsparky's Avatar
Looks like a hack job. My gut says the inspector won't go for this.
"Conduits shall be properly terminated into the enclosures...."
-KB
kbsparky is online now   Reply With Quote
The Following 4 Users Say Thank You to kbsparky For This Useful Post:
frenchelectrican (01-06-2013), HIVOLT (01-05-2013), micromind (01-05-2013), mpoulton (01-06-2013)
Old 01-05-2013, 06:42 AM   #4
Lic Elect/Inspector/CPO
I agree.
Where are you located that only 1 Electrician would get back to you.
Down by me there does not seem to be that issue.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
HIVOLT (01-05-2013)
Old 01-05-2013, 06:49 AM   #5
Licensed Electrician
k_buz's Avatar
It would fail without question in my parts.
Location...Location...Location
Old 01-05-2013, 07:45 AM   #6
How did you get such a ragged hole in the side of the breaker panel?
Use a nipple (not the plumbing kind) threaded on both ends rather than that piece of conduit. Unmount and move the transfer switch box a tad so the nipple fits.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-05-2013, 07:55 AM   #7
k_buz's Avatar
Personally, I would run a piece of 6/3 NM. Take out the sub and close the holes you are currently using for the conduit. Then knock out a 3/4 KO. Use a piece of 6/3 NM (edit: with listed connectors)
I would be interested in seeing a better picture of the subpanel as it appears to be that you are landing the grounds on the neutral bar.
Old 01-05-2013, 08:09 AM   #8
Master Electrician
Hack job times ten. What did you cut the hole in the main panel with, your teeth? That's not gonna be an easy fix without a slug buster.
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
Old 01-05-2013, 08:27 AM   #9
Square D makes a mighty fine interlock kit:
http://members.rennlist.org/warren/SQDinterlockkit.pdf
Auger01 is offline   Reply With Quote
Old 01-05-2013, 11:35 AM   #10
deverson's Avatar
This has no chance of passing a with a poor inspector let alone a decent one. Very hack!
deverson is online now   Reply With Quote
Old 01-05-2013, 06:23 PM   #11
Okay okay... I didnt say it was a pretty job. LOL
But ive been thinking about this all day, after reading your posts.
First I know I need to close up the mess I created on the main panel side.
Can I use a square piece of sheet metal and screw it into the panel? then mark with a pencil from the switch side and drill a clean hole in the sheet metal ?
I think AllanJ has a good idea using a threaded sleeve and tightening it on both sides sounds like a good idea?
Side bar... We are located in ocean county by the shore, and all the electricians have been super busy with jobs located on the barrier islands with all the flood damage.
Old 01-05-2013, 06:36 PM   #12
kbsparky's Avatar
I have used blank cover plates to "repair" such damages to panel box enclosures in the past. I'd try using the 4" octagon blank plates, which may fit without having to cut them down first.
You can get them at most hardware or home-horror stores for under a buck a piece.
A rigid pipe nipple with lock rings on both sides of each enclosure and insulating bushings would make this installation much more palatable.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
Durkis007 (01-22-2013), micromind (01-05-2013), mpoulton (01-06-2013)
Old 01-05-2013, 07:23 PM   #13
You might have go out of ocean county, but I know there some electricians in Monmouth county that could probably help. You do not have an email in your profile, so I could not contact you directly.
Old 01-06-2013, 04:57 PM   #14
remodeling pro
I'm not a licensed electrician, but that will be a "NO", in capital letters. You can probably save yourself by slipping a proper length threaded nipple through there, with pvc anti chaffe collars screwed on the ends. I'd try to "dress up" the panel penetration that you chewed your way through with a screwdriver or chisel with a bead or 2 of gray or silver silicone.
troubleseeker is offline   Reply With Quote
Old 01-08-2013, 01:24 PM   #15
Uggghh. That will look worse and attract more unwanted attention from the inspector in terms of suitability for application inside a service disconnect panel. Plus, out-gassing of the silicone as it cures is no friend to electrical contacts.
Wrooster
wrooster is offline   Reply With Quote
Generac 10KW generator and Generac RTS12EZA1 transfer switch. exhdo1 Electrical 8 11-30-2011 03:33 PM
generator transfer switch chuck172 Electrical 8 06-30-2011 04:34 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 08:45 PM
