Old 01-01-2013, 02:42 AM   #1
Question
Installed single pole dimmer, three of four lights dim
Hello,
I installed a single pole slide with switch dimmer today in a room that has one light switch that controls four canned ceiling lights. After installation, three of the four lights dim, the fourth stays on at full power or off, depending on the switch. When the slide is dimmed all the way down, the fourth bulb remains on. What could cause this? And how to fix it?
Thank you!
Peg2326 is offline   Reply With Quote
Old 01-01-2013, 04:51 AM   #2
Devil Dog
handyman_20772's Avatar
Have you checked the wiring? And, how many watts is the dimmer rated for? You may have exceeded the total wattage for that particular dimmer.
handyman_20772 is offline   Reply With Quote
Old 01-01-2013, 06:02 AM   #3
Lic Elect/Inspector/CPO
I would check the wring.i
NJMarine is offline   Reply With Quote
Old 01-01-2013, 07:39 AM   #4
Different kinds of lights may behave differently on a dimmer. Are all four lights the same? Is the fourth light intended for use with a dimmer (if not incandescent)?
Note that the dimmer output voltage at any slider position may vary depending on the load. So the fourth light may behave differently if you unscrewed the lamps from the first three fixtures.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-01-2013, 07:43 AM   #5
Licensed Electrician
k_buz's Avatar
I'm guessing the 4th is a non dimmable CFL.
Location...Location...Location
The Following 2 Users Say Thank You to k_buz For This Useful Post:
NJMarine (01-01-2013), Speedy Petey (01-01-2013)
Old 01-01-2013, 08:44 AM   #6
joed's Avatar
Does the fourth light go off if you turn the dimmer completely off?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-01-2013, 09:09 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
My thoughts too.
Outdoor Patio Lights to Dimmer mginster Electrical 1 12-27-2012 05:41 PM
Puck lights with touch dimmer 830ttime Electrical 4 11-15-2011 01:37 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 01:37 PM
Adding 4 Recessed Lights to single wire themayor Electrical 5 02-05-2009 05:08 PM
