Installed a new receptacle, now foyer lights don't work?
I replaced an electrical outlet in the living room (connected to the foyer circuit breaker, however) to one with the USB plugins in the middle. When I opened the old receptacle, it had 5 wires: 2 whites, 2 blacks, and ground. All of them were attached to the old receptacle. The new receptacle only had 3 wire connections so I connected one of the black, one of the white, and the ground and then pushed the other black and white back through the hole at the back so that they weren't touching (I'll cap them tomorrow when I can get to the store.)
Okay, so here's the problem - now the foyer light (a chandelier type with 5 bulbs) and the porch light won't switch on anymore. I've tried fully resetting the foyer breaker a few times to no avail. I can't think of what went wrong - does it have something to do with those two wires I left unconnected? The new receptacle works just fine, by the way, and it's on the same breaker. Thanks ahead of time for any help! -Adam |
How many terminal screws are on the new receptacle? and is a duplex receptacle your replacing? |
No, it's not a duplex (if I'm interpreting what duplex means). There are only 3 points on the receptacle - black, white, and green. The old receptacle had 5 points. So, if I want to keep this receptacle, what can I do to keep the future lights on the circuit active? Just connect the extra black to the same wire nut as the black going to the receptacle and same for white?
you will need a short piece of electrical romex wire, either 14/2 or 12/2 depending on what is currently there. Cut the wire approx 3 -4 inches, remove the white and black wires from the romex and strip both ends of both wires. Wire nut one end of the black wire to the two black wires in the box, the other end loop it and secure it to the proper terminal. Do the same for the white wire -
Those wires you left unconnected fed power to your lights.
1 Attachment(s)
Does your new outlet look like this?
I did it and it worked. Thing is, instead of the romex wire you suggested, I just put all three ends (black, black, and receptacle black) into one wire nut and twisted down. I did the same for the whites. All the lights came back on and everything seems kosher.
Is it safe to keep it this way or does the romex wire make it safer? |
More like this one ?
http://www.cooperindustries.com/cont...R7740W-220.jpg If so follow Fltdek's instruction it will be very specfic answer there and got it correct at the point. So you will have to make a pigtail for this device to get the rest of the circuit working. Two short peices of conductor #12 or #14 depending on what it is on plus 2 wire nuts either yellow one or red one depending on size again. Once you get the pigtail done the rest of the circuit will be working properly. Merci, Marc |
Pretty much sums it up, but would be nice if you could post a pic just so we can see what your working with.. |
The mentioning of USB in the OP threw me off for a minute...although I have seen these in stores and online, just haven't come across them in any homes.....yet
| All times are GMT -4. The time now is 10:59 PM. |
