Installed New Light - Won't Work! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 01:16 PM   #16
Electrician
ctsmiths's Avatar
Rewards Points: 150
Installed new light - won't work!
Originally Posted by stressfreak View Post
i just tested the multimeter and the black wires from the ceiling do not have any power. i guess i have to replace those. argh, thanks.
You tested the black wires with the power on? So you were able to get the breaker to stop tripping? I was going to tell you to, with the power off at the breaker, check resistance between the blacks and the box, also the blacks and the neutral and the blacks and the ground ( if the ground is not tied to the box) if you get an OL then you are ok, if you get a ohm reading between any of these then that is where your problem is.
ctsmiths is offline   Reply With Quote
Problem Installing Track Light MrBill_DIY Electrical 5 11-12-2008 10:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
Ceiling fan trouble wiring Foxtrot_01 Electrical 8 08-03-2008 02:08 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
