Installed New Light Switches And Now Fan/light Won't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 05:07 PM   #1
Installed new light switches and now fan/light won't work
Hey, I don't have much technical info to give. But the situation is we installed new switches and the only ones we are having problems with are two switches with a fan/light attached to it. One in particular is a regular light switch to the left with a black/black/ground (works fine) and another fan/light switch to the right with a black/black (doesn't work) We've tried switching back to the old stuff and still won't work. None of the lights are controlled by a 3-way switch, and the light/fan was working fine before. Breaker is not broken, light bulbs are good.
Its a mystery to us and its really frustrating.
theemorgandorfe is offline   Reply With Quote
Old 05-24-2010, 08:40 PM   #2
Possibly an iffy wirenutted connection upstream finally failed. You could try temporarily replacing the two terminal switch with a very small 120v incand. bulb and see if it lights, even dimly.
Old 05-24-2010, 10:13 PM   #3
Got it
Finally figured out that we had the switches wired wrong. they were 3 pole switches which we knew, but the one wire was not ground it was connection to the adjacent switch. Thanks for help though
