-   -   Installed new light switches and now fan/light won't work (http://www.diychatroom.com/f18/installed-new-light-switches-now-fan-light-wont-work-72011/)
theemorgandorfe 05-24-2010 05:07 PM
Hey, I don't have much technical info to give. But the situation is we installed new switches and the only ones we are having problems with are two switches with a fan/light attached to it. One in particular is a regular light switch to the left with a black/black/ground (works fine) and another fan/light switch to the right with a black/black (doesn't work) We've tried switching back to the old stuff and still won't work. None of the lights are controlled by a 3-way switch, and the light/fan was working fine before. Breaker is not broken, light bulbs are good.
Its a mystery to us and its really frustrating.
Yoyizit 05-24-2010 08:40 PM
Possibly an iffy wirenutted connection upstream finally failed. You could try temporarily replacing the two terminal switch with a very small 120v incand. bulb and see if it lights, even dimly.
theemorgandorfe 05-24-2010 10:13 PM
Got it
Finally figured out that we had the switches wired wrong. they were 3 pole switches which we knew, but the one wire was not ground it was connection to the adjacent switch. Thanks for help though
