Installed New Fluorescent Fixture But Lights Are Dim... - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 05:55 PM   #1
Installed new fluorescent fixture but lights are dim...
I am replacing pull-string bulb fixtures in my basemenmt with new 2-bulb 32W T8 fluorescent fixtures. The first one is working perfectly. The second one is only about half the brightness of the first. Could it be grounded wrong? I'm using BX and running it from a switch so I can light the whole liine with a single switch instead of "pull-stringing" each light along the entire 35' of basement. I tried fiddling with the bulbs but they still are darker than the other. Should the bare ground wire not be loose inside the covered box in the center or???
montero is offline   Reply With Quote
Old 03-02-2011, 06:28 PM   #2
I=E/R
a7ecorsair's Avatar
Grounding isn't part of the current flow. You probably have something wired wrong. How many of these fixtures will you be installing? Are you adding cable or is there an existing ceiling box for each new fixture?
a7ecorsair is offline   Reply With Quote
Old 03-02-2011, 06:34 PM   #3
Its an unfinished ceiling so I'm fastening the fixtures to the studs and attaching the BX with the connectors to the top of each fixture. I'm planning on 6 fixtures total.
I took the cover off of my wiring and checked eveything, put different bulbs in and it works normally now.
Old 03-02-2011, 06:39 PM   #4
-sorry, I'm adding NEW BX along the line. I'm not fooling with the old. I'm running it from the existing BX where it comes from the box, has two switches, one at the top of the stairs, and one at the bottom.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Wiring 4 lights to 1 switch...Please help! Driven2race Electrical 14 01-17-2010 07:03 PM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 06:51 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
How to switch fluorescent lights Carissa Electrical 3 08-16-2008 03:28 PM
