Installed New Chandelier, Bulbs Flashing Won't Turn On - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 10:29 PM   #1
Lightbulb
Installed new chandelier, Bulbs flashing won't turn on
I just installed a new chandelier and used those energy star coil looking bulbs and when I turned the light switch on the bulbs flicker and flash but won't turn on. When I replace one energy star bulb with a regular 60 wt bulb everything lights up just fine. Did I do something wrong? Or could it just be an issue with these bulbs? Also when I put the 60 wt bulb in it lit up fine but had a line of shadow in the bulb. I'm so confused....
Ctorres43 is offline   Reply With Quote
Old 04-12-2010, 01:24 AM   #2
Master Electrician
they're on a dimmer i'm guessing? You have to either get an electronic dimmer for flourescents or get special dimable bulbs if your going to have them on a dimmer.
andrew79 is offline   Reply With Quote
Old 04-12-2010, 08:03 AM   #3
Talking
Yep that's it!
It hit me this morning that the chandelier is attached to a digital dimmer switch... You are correct. I guess I'm gonna have to use regular bulbs instead. Shew at least I hooked everything up right. Thanks for your reply! :o)
Old 04-12-2010, 10:25 AM   #4
Master Electrician
they do make special bulbs that have a dimmable ballast in the base for dimming if your set on it...otherwise you would have to replace the dimmer with one special for flourescents
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 07:01 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
LED Bayonet Bulbs? Minok Landscaping & Lawn Care 1 12-10-2008 10:38 AM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
