Installed Doorbell - Chiming Not Right - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2008, 03:21 PM   #1
Installed doorbell - chiming not right
The old doorbell sounded weird, so I bought a new one. I've just installed this new Heath-Zenith hardwired mechanical chime, but it still sounds funny (the first tone---the highest tone---sounds like a buzz most of the times; the second and lower tone works okay). I looked on their web site and they mention a bad diode. What the heck is a diode? I think they said it's something in the doorbell push button, and not the mechanical chime device itself. Can you offer any help?
proofer is offline   Reply With Quote
Old 07-06-2008, 03:40 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Go to the doorbell switch and take the two wires and put them together, if it works good then replace the PB. It's just a switch so all it's doing is putting those 2 wires together.
wirenut1110 is offline   Reply With Quote
Old 07-06-2008, 03:47 PM   #3
Rewards Points: 510
PS a diode is like a check valve. It only allows electricity to flow in one direction. To check it you would put your meter on ohms place your leads across the 2 leads from the diode, then switch the leads, you should only get a reading in one of those if you get a reading in both, the diode is bad.
Old 07-08-2008, 04:04 PM   #4
Thanks, Wirenut, for all the info. The push button hasn't been replaced in a long time, so I think I'm just going to get a new doorbell. That should fix the 2-wire issue as well as the diode issue. Appreciate your help on this one.
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 01:53 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-22-2007 12:08 AM
Tried replacing doorbell....now it doesn't work. ConstantChange Electrical 9 11-18-2007 11:12 PM
Just installed LG dishwasher--there's a buzzing sound. naiLS1 Appliances 1 04-15-2007 10:22 AM
