Installed Ceiling Fan, Now Kitchen Lights Won't Work... - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 06:35 PM   #1
Question
Installed ceiling fan, now kitchen lights won't work...
We installed a ceiling fan last weekend, which works great! However, the ceiling lights in the kitchen, which is adjacent to where the fan is now, won't turn on. They're recessed can lights.
The fan doesn't have lights, which is what we wanted. However, we planned on having our normal kitchen lights!
Any help is appreciated. If it's something simple, we would prefer to do it ourselves instead of calling an electrician--and paying an electrician.
Help!
jodiehunter09 is offline   Reply With Quote
Old 05-26-2011, 07:59 PM   #2
Licensed electrician
Rewards Points: 1,456
How many and what color were the wires and cables in the fan box? Did you leave any unconnected?
Old 05-26-2011, 08:16 PM   #3
Trial & error
There are 2 white wires & 1 orange wire. We tried all combinations of wiring & none brought the kitchen lights back on.
All wires are connected.
Old 05-26-2011, 08:18 PM   #4
Can you describe the connections you made?
Old 05-26-2011, 08:35 PM   #5
Colors
Okay, here goes.
Black & Blue fan wires to orange ceiling wire
Ground wire (green) from fan to 1 of 2 white wires from ceiling
White fan wire to other white ceiling wire
Old 05-26-2011, 08:40 PM   #6
The green should not be connected to the white. I suspect that both whites go together.
Old 05-27-2011, 12:17 AM   #7
Rewards Points: 512
yep, you lost your kitchen light neutral (a white wire) by not connecting it to the other whites. The ground wire goes to a green ground screw on the fan box, or to other bare or green wiwres in the box.
Old 05-27-2011, 07:16 AM   #8
Thumbs up
Yay!
Awesome! I have have the hubby fix it when we get home this evening! I will let you know if it doesn't work, but I'm hoping it fixes the problem!!
Thank you so much, Jim and Sirsparksalot!
ceiling fan lights don't work cvtlavt Electrical 17 01-14-2011 07:25 PM
No Kitchen Lights misslemike Electrical 3 12-26-2010 04:23 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 11:52 AM
Installed a dimmer and now upstairs lights don't work pablo_ottawa Electrical 2 08-31-2009 05:39 AM
Help...Sheetrockers knocked out ceiling lights westing Electrical 6 05-01-2007 12:59 PM
