Old 01-08-2012, 05:32 PM   #1
PJR
Installation of a SunSmart Digital Timer
I am trying to install a SunSmart Digital Timer to my hall lightswitch (single pole). The timer has 5 wires: Black, White, Blue, Red, and Green. My switch box only has 3 wires: Black, White, and the bare ground wire. I connected the black to the black, white to white, and green to the bare ground. I have power to the timer but the light doesn't work. What should I do with the blue and red wires? Right now I have each capped off. Thanks.
PJR is offline   Reply With Quote
Old 01-08-2012, 06:21 PM   #2
MarginallyQualified
Originally Posted by PJR View Post
SunSmart Digital Timer to my hall light switch (single pole).
The timer has 5 wires: Green, Black, White (plus Blue and Red)
Your box has only "switch leg" wires.
Your fancy schmancy timer needs a neutral to work...
and maybe even other wires.
What do the instructions say to do?
TarheelTerp is online now   Reply With Quote
Old 04-25-2012, 09:44 PM   #3
I am in a similar situation with my knob and tube wiring in my house. Have you made any progress, or does anyone have any input?
thomas.granbois is offline   Reply With Quote
Old 04-26-2012, 06:56 AM   #4
Black from timer goes to line power.
White from timer goes to neutral.
Blue from timer goes to load power.
Green from timer goes to ground.
Red from timer is capped off.
If you do not have a neutral(just because a conductors insulation is white does not mean it is a neutral) then you cannot use this timer.
Here is the timer you need.
http://www.jascoproducts.com/product...ly-80p1142.htm
hammerlane is offline   Reply With Quote
Old 04-26-2012, 07:33 AM   #5
Heres how you need to hook it up.
Problems, GE SunSmart Digital Timer 15312 Mike Muls Electrical 31 04-19-2013 05:38 PM
GE Sunsmart Digital timer appears to be dead michaelhager Electrical 5 11-26-2011 11:52 PM
GE Smart Digital Timer Installation SJJane Electrical 4 09-08-2011 01:53 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
In-wall Digital Timer Installation worked Electrical 3 08-02-2010 10:42 AM
