Installation Of 4 Ceiling Light + Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 09:44 AM   #1
Installation of 4 ceiling light + wiring
Does anyone know how long does it take to install 4 ceiling light fixture + wiring in the 2nd floor normally, given that I used stand up lamp for all 4 of my bedrooms?
The electrician I hired took 17 hours to complete the task. He was having a lot of difficulty getting the box behind the receptacles and switches out of the drywall because it was nailed onto the stud.
Also when he place the switch back into the drywall, all of them is slanted toward one side, he claims it is screw onto one side of the stud, which causing it to pull toward that side only and there is no way around it.
Lucas9394 is offline   Reply With Quote
Old 09-18-2013, 10:09 AM   #2
Rewards Points: 2,516
Originally Posted by Lucas9394 View Post
Does anyone know how long does it take to install 4 ceiling light fixture + wiring in the 2nd floor normally....
I think you answered your own question.
As you have not provided any details like was there an attic above the 2nd floor to work in and run the power, is there insulation in the walls, did he use cable or conduit. Too many variables
hammerlane is offline   Reply With Quote
Old 09-18-2013, 10:12 AM   #3
i suspect you're asking if 17 hours is a reasonable amount of time for the task but like hammer points out, there are dozens of variables that can impact the effort. sketches, pics, etc. would be helpful.
itsnotrequired is offline   Reply With Quote
Old 09-18-2013, 10:15 AM   #4
There is an attic above the 2nd floor and he used cable
Old 09-18-2013, 10:24 AM   #5
Yes I just want to know if it is reasonable and if I should hire them again for future. When they were giving me a quote, which was a really good quote, I told them I have electricity in the 4 bedrooms and it is currently using stand up lamp, I need them to rewire and install 4 ceiling lights and there is an attic for them to go up to.
I just didn't expect them to take this long, initially they were thinking 3 to 4 hours, but it ended up taking 17 hours!!!
Basically I just wanted to know if the amount of time was reasonable and if there is a better way to mount the box inside the switch onto the stud better, because right now it is slanted toward one side for all the switches
Old 09-18-2013, 11:28 AM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Yes. 17 hours is excessive with attic access.
As for the the boxes he should have used "old work" boxes. No slant issues with them.
We're they paid by the hr or flat rate for the work?
sublime2 is offline   Reply With Quote
Old 09-18-2013, 11:37 AM   #7
They came in a team of 2, one certified electrician and one assistant that doesn't seem to know too much. It was a flat rate for the work and the guy charged me another $100 dollar extra due to some wiring issue. I'm very happy with the price, because majority of the place was quoting me $200 to $300 per ceiling light, and who know how much more they will charge once they start working on it.
The price was great, but the craftsmanship wasn't the best, I guess you get what you paid for.
Old 09-18-2013, 11:52 AM   #8
You may of misunderstood.
Maybe he was suggesting 3 to 4 hours per room.
Times 4 rooms that 12 to 16 hours.
If you can post a photo of the boxes you say look sloppy. Take the cover plates off too.
Old 09-18-2013, 09:50 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If you paid a flat rate and your happy with the rate and the work, what's the problem?
Very true!
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Old ceiling light wiring help!! Budl09 Electrical 7 08-28-2011 08:06 PM
confused re wiring on ceiling light stel Electrical 6 08-07-2011 02:22 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
