Install Programmable Light Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 05:45 PM   #1
install programmable light timer
Replacement wall light timer has three wires, namely blue, black/brown, & green. The wall box also has three, but they're black, red, and white. Now what?!
pupdog is offline   Reply With Quote
Old 10-14-2012, 05:47 PM   #2
so how does this work? when do I get an answer? and where?
Old 10-14-2012, 06:07 PM   #3
Rewards Points: 150
IF someone is able to help you, their response will appear here.
Seldom will you get replies in two minutes, however.
Dave632 is offline   Reply With Quote
Old 10-14-2012, 08:58 PM   #4
Oso954's Avatar
Rewards Points: 980
It also helps to provide the maker and model of the timer.
There are tens if not hundreds of them.
Oso954 is online now   Reply With Quote
Programmable electronic timer switch to electronic door lock? freedom1st1776 Electrical 19 03-10-2012 09:39 AM
20A GFCI Switch Combo or Programmable Timer megablok Electrical 2 12-07-2011 03:14 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 11:02 AM
Attempt to install a in-wall digital timer switch prabal Electrical 5 11-28-2010 09:18 PM
Recessed Light Install Question kennykenny Electrical 2 12-03-2008 10:00 AM
