Install outlets in block wall
might consider dropping the wires down then just mount them into a box on the cinder block,inside the block might have to just chisel a square...might make a template out of 1/4 wood to fit the box then spray paint the squares around where you want them...if the walls are being built,take the block and do it on a bench then do a bunch of them for the switches and sockets...as you build it keeping in mind the wire drops or coming up from a basement.YOUTUBE has a ton of ideas going into tiles concrete walls for such..easiest seem to be do that template then use masonary bits drilling holes around then chip it out so the blocks can be grabbed during building
