Install New Receptical? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2006, 03:58 PM   #1
install new receptical?
hello, i have a house with two decorative ledges that i would like to add an outlet for rope lights. there are a couple outlets on the wall under the ledge that i should be able to get power from. is it ok to run romex behind the wall(parallel) up to the decorative ledge for the new outlet. what is the best way to go about this project?
starnz is offline   Reply With Quote
Old 07-21-2006, 04:47 AM   #2
Sure it is ok. get a couple old work boxes and associated hardware.
cut the outlet box out above where you want the new one and drop a string in the wall weighted down with a small nut. Knock out a hole in the existing box in the top and use a scrap wire to reach in and grab the string. Use the string as a pull line to pull the wires in.
Lets hope that there are no perlines in the wall or you will not be abe to fish past them easily. Sometimes we just end up having to do some damage to the walls.
jwhite is offline   Reply With Quote
Old 07-21-2006, 03:34 PM   #3
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
It would be a good idea to run a stud finder over the wall from the top outlet to the bottom just to ensure that noone put a cross brace from stud to stud anywhere first.
J187 is offline   Reply With Quote
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 02:23 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
interior door install ? bboy Carpentry 1 01-17-2007 09:23 PM
