-   -   Install new motion light, where should I connect it? (http://www.diychatroom.com/f18/install-new-motion-light-where-should-i-connect-150741/)
kanigit 07-18-2012 09:44 PM
Hi Everyone,
My first post here! Looks like there is a lot of great information out there, if this has already been covered than I apologize. I'm looking to install an outdoor flood motion light in the backyard. I live in a one story ranch with basement (if that helps) and accessible attic.
There are no lights on the back of the house currently, however there are two GFI outlets on the far ends of the exterior. I am planning to install the light on the soffit in the center of the building above a bedroom window.
My question is, where should I tie into the electrical system? Does it make the most sense to run new wires from the panel (200 amps!), piggy back off the circuit in the joining bedroom, or possibly the easiest choice would be to piggy back the attic light wiring. It's already accessible and fairly close to where the light would be installed. Any thoughts on how I should go the best, safest, method?
I have minimal experience with eletrical work and have only replaced outlets and did some wiring runs back in high school, never added to an existing system. Im also reading through some books. Lastly, feel free to suggest any particularly good motion lights, brand or type of wiring I should use, etc.
Thanks in advance!
AllanJ 07-18-2012 10:09 PM
I would prefer to piggy back it off of the attic light circuit.
It is okay to piggy back it off of the bedroom circuit except if the outdoor light uses significant power (such as more than 200 watts) you increase the chance you would trip the breaker if a lot of things (like audio/video or a hair dryer) were being used in the bedrooms.
kanigit 07-19-2012 05:55 AM
AllanJ,
Thanks for your response. I forgot to mention it, the attic light is controlled by a switch from the hallway. I could probably use that for turning off the motion light I suppose and toggle the attic light independently. Not sure if that makes sense.
Do I need to wire the attic junction box in any special way?
