Old 02-06-2013, 11:30 AM   #1
install new ele wire on 408 sq ' cabin
is this answer free is there a charge
358053 is offline   Reply With Quote
Old 02-06-2013, 11:34 AM   #2
The answers are free but sometimes take a long time to get for difficult questions.
You typically pay for the line from the utility pole to your house (the service drop).
In many locations you have to pay for extending the utility power lines and adding poles up your street to your house if none already exist.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 02-06-2013, 11:48 AM   #3
J. V.'s Avatar
True log cabins are not for the DIY'er. Even licensed qualified electricians may not be familiar with log home construction. Especially the electrical end of it. This is a job I would say you need professional help with.
The Following 3 Users Say Thank You to J. V. For This Useful Post:
frenchelectrican (02-07-2013), jbfan (02-06-2013), mpoulton (02-06-2013)
Old 02-06-2013, 11:55 AM   #4
Semi-Pro Electro-Geek
Electrical in a log cabin is hard because of the construction type. It's just very difficult to run wires through stacks of solid logs. Like many other aspects of log construction, there are very specialized tricks and techniques to use, and not many people know how to do it these days.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-06-2013, 11:59 AM   #5
MarginallyQualified
How much power does a 20' X 20' cabin need? Or want?
An LP refrigerator will keep the bait and beer cold...
what else do you need?
TarheelTerp is online now   Reply With Quote
Old 02-06-2013, 05:20 PM   #6
Well, with proper planning it's not THAT hard. My wife and I live in a log home we built almost entirely by ourselves. And we are not professional tradesmen of any sort, just skilled DIYers. Hiding HVAC ducting is a lot more difficult.
Old 02-06-2013, 07:59 PM   #7
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If this is a modern log home it's usually pre drilled for the wiring and holes just have to be cut for the boxes. Last one I was working at on site they would drill a hole through the wall for the wires and mark on the floor where the hole was so we knew where to go and just had to cut out at the desired height and ones that fed upstairs were also marked out.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-06-2013, 08:28 PM   #8
MarginallyQualified
Originally Posted by rrolleston View Post
If this is a modern log home...
It's a 400 sq foot (20x20) cabin.
Probably just like all the other fishing cabins on the lake.
No real need for power is mentioned.
No logs are mentioned either.
Old 02-06-2013, 08:49 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
I've done many many real log homes. I have not seen one that was pre-drilled. Every time we'd either have to be on site to drill out own holes, or lay out the holes with the builder and they drilled them as they set logs.
I highly doubt the OP is talking about logs though. I agree, more likely just like the image above.
Speedy Petey is online now   Reply With Quote
Old 02-06-2013, 09:47 PM   #10
rrolleston's Avatar
That is what I mean by pre drilled. The architect or contractor had in the plans where they were supposed to be and they drilled them as they were going. So when we got to the upstairs everything was already drilled for us.
They do have kit log homes that everything is cut and drilled and numbered at the factory and basically goes together like leggo's. A place around here does it.
The Following User Says Thank You to rrolleston For This Useful Post:
Speedy Petey (02-07-2013)
Use red and black wire as 110 in Canada mattm Electrical 10 11-26-2012 08:40 PM
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
Wiring help three wire to two wire install israelsoto99 Electrical 1 06-28-2009 11:24 AM
