Install Kitchen Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 07:36 PM   #1
Install kitchen light
I am trying to install a Hamptonbay kitchen light. The fixture has a black, white and ground. Coming out of the ceiling is a black, white, red and ground. I assume the black goes to black, white to white so what do I do with the red. This is being installed on a 3 way switch.
Firedog1 is offline   Reply With Quote
Old 11-06-2010, 08:17 PM   #2
was this a location where there was once a ceiling fan? Just three wires in the box: red, black, white, no more? Do you have a volt meter? Perhaps the red was a spare, just in case one wanted to install a ceiling fan at some future point in time.
oberkc is offline   Reply With Quote
Old 11-06-2010, 08:18 PM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
He said it was a three way switch........
tcleve4911 is offline   Reply With Quote
Old 11-06-2010, 08:36 PM   #4
I saw that. Thanks. I am not sure that this explains the three wires in the switch, however. Nor do I see how this gives a clue about what to do with the extra red cable.
I could be wrong. Or perhaps I misunderstand his meaning of a three-way switch.
Old 11-06-2010, 08:45 PM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You're right.
The red wire just goes from switch to switch.
Earlier post suspected a ceiling fan
I think he's right....but not sure.
Old 11-06-2010, 08:51 PM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Another one
Old 11-07-2010, 02:54 PM   #7
I am trying to replace a kitchen light. With the old light I had a light switch on each side of the kitchen. Someone else disconected the light so I did not see how it was wired. I would like to connect it so I can continue to use both switches. Since the black is the hot should I connect the red wire with the black?
Old 11-07-2010, 03:29 PM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
If we assume the red was for a ceiling fan light, then the answer will be no.
The black should be hot, white neutral, green ground.
You will cap off the red wire in the box since you no longer need it.
Old 11-07-2010, 04:56 PM   #9
At this point, we are making a lot of assumptions. You have not responded to my original question about whether you have a volt meter. This would be really handy to reach some conclusions without so many assumptions.
Or you can wire it up white to white, black to black, cap the red, and hope it works. It might. Hopefully it will not cause any damage.
Old 11-07-2010, 08:48 PM   #10
tcleve4911
tcleve4911 thank you for helping. I'm a single mom trying to do home improvements with my daughter. Most of the projects have been easy but time consuming. The electrical has been the hardest.
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 01:08 PM
Kitchen faucet threads - install swivel aerator USEYOURHEAD Plumbing 2 10-09-2010 12:30 PM
Hanging chain light in the kitchen; I'm need wiring advice. fcwedd Electrical 2 05-04-2010 08:50 PM
HELP: two-wire light switch install ryanonline Electrical 2 06-14-2008 06:50 AM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 01:05 PM
