Old 01-22-2013, 03:27 PM   #16
JOATMON
ddawg16's Avatar
Install ground rod - middle of the winter!
Originally Posted by Canucker View Post
Good god, ddawg, you live in southern Cal, have you seen frost other than in your refrigerator?
Come to think of it? No.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-22-2013, 05:02 PM   #17
curiousB has the right tool. Works great in rocky ground also where a sledge is almost a futile exercise.
Cornhusker Joe is offline   Reply With Quote
Old 01-22-2013, 06:22 PM   #18
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Here you go
Ground rod driving
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-23-2013, 09:05 AM   #19
Originally Posted by rrolleston View Post
Here you go
Ground rod driving
Now that's what I'd call overkill. You'd have to be driving an entire subdivision's worth of rods to justify the cost of renting something like that.
Old 01-26-2013, 10:58 PM   #20
Just wanted to post the success.
Ended up renting an SDS max hammer drill and ground rod driving bit and also a 5/8" masonry bit. Predrilled an 18" deep hole for each rod, then set the rod in, and pounded in using the hammer drill with the rod driving bit. It went straight down, easily, no problems at all. Left about 12" above grade, attached #6 copper to both rods (continuous run) and fed into the house.
Thanks for all the advice!
I'll wait for inspection for sure, probably even wait till spring, then drive the rods the rest of the way down and trench out a little for the #6 wire.
F
fdmillion is offline   Reply With Quote
Multiple Ground Rods, help Ralph III Electrical 72 02-14-2012 10:31 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 07:34 PM
How to install a ceiling fan w/o a ground karebear09 Electrical 8 08-01-2011 08:48 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
