Old 01-21-2013, 07:56 PM   #1
Install ground rod - middle of the winter!
So, I have one last thing I need to do before my inspector comes out...
Got my 4/0-4/0-2/0 main service drop installed, new meter base hooked up, and am all set with the new load center - just going to switch it in as soon as power company shuts main power off. Shouldn't take me more than an hour to pull the old center and wires and drop in the new center and all of the circuits I'm ready to have inspected and turned on.
So... Based on local codes and in checking with the city and power company, I need to add ground rods to my new service - grounding to plumbing isn't sufficient.
Lowe's sold me the rods and the connectors so I have everything I need.
Except, here in MN, temps are currently sitting below 0...
I've heard of a few different ways to get this done mid-winter... Some people have talked about using some form of heater and letting it sit there for several days, but this may not be the best option due to the time needed, not to mention I'm not sure how much something like that costs...
I've also heard of using either a masonry or auger bit on a hammer drill just to get below the frostline, but others have said that this won't work and would probably damage the bit and the drill before actually getting anywhere.
I've also heard about just using a plain sledgehammer and working until the rods finally break through, but this seems like it wouldn't work too well - the ground is obviously pretty solid and I'd probably bend the rod before getting any real depth.
I don't know if the inspector will approve anything to be energized without these as they are required by code...
Anyone have any advice on this?
This honestly was a little (but significant) oversight - I got my permits and everything in order long ago, but didn't get going with the electrical until it was starting to get cold out... and now it's way TOO cold!
If the inspector won't approve it, I'm afraid to have the old service shut off, because I'd be without power (And thus without heat!) But at the same time, the old system is horribly unsafe, and I don't feel at all comfortable using it any longer than it needs to be used!
Advice please? Thanks!
F
fdmillion is offline   Reply With Quote
Old 01-21-2013, 08:00 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... In my experience, the rod itself can be driven by a big enough hammer drill, will sink a rod, as quickly as you can push it down,....
Frozen or not...
Old 01-21-2013, 08:17 PM   #3
Electrical Contractor
Rent a hammer drill with a ground rod attachment.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
The Following 2 Users Say Thank You to jbfan For This Useful Post:
HIVOLT (01-22-2013), Missouri Bound (01-23-2013)
Old 01-21-2013, 08:18 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
As long as it has not been below freezing for a couple of weeks, you should be fine right now. Now of course if you wait until this Saturday, you may have an issue if it does not warm up. Especially that MN is getting -20 to -50 below, depending on where you are.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 01-21-2013, 08:22 PM   #5
kbsparky's Avatar
Hammer Drill a hole thru the frozen ground, then insert the rod and drive it the rest of the way with your sledge. If a hammer drill bit can punch through concrete, why not ice?
-KB
Old 01-21-2013, 08:47 PM   #6
gregzoll's Avatar
Here is a map of current ground temps at 6" below the soil http://gis.mda.state.mn.us/maps/csgsoil.htm Looking at it, you have nothing to worry about, so get driving.
Old 01-21-2013, 09:00 PM   #7
A heavy duty roto-hammer will get the job done in no time.
There is a difference between a hammer-drill and a roto-hammer or demo-hammer btw. You want a big roto/demo-hammer set to hammer only mode.
It will go through that ice like it isn't even there.
Once you start trying to drive 8 foot rods through hard ground with a sledge hammer you will quickly be willing to give power tools a try.
dftc is offline   Reply With Quote
Old 01-21-2013, 10:21 PM   #8
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you can rent a tool to drive them I would do it because I have driven them in the winter with a sledge and it's not a pleasant experience.
They have a point and you can make it a little sharper to help you get started.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-22-2013, 12:37 AM   #9
Great advice guys
Gonna try renting the roto-hammer, I think our tool rental place has them.
Do you recommend I get a bit and pre-drill down into the ground? That's what I was thinking made the most sense... I was also seeing that some roto-hammers can actually just grab the grounding rod in the chuck and hammer it without any extra attachments... so sounds like what I'd do is pre-drill down into the ground as far as I can go, and then just throw the rod in and start hammering away.
Actually looks like this may be simpler than it seemed.
f
Old 01-22-2013, 01:52 AM   #10
JOATMON
ddawg16's Avatar
It's the middle of winter here.....really cold....I wouldn't have any trouble driving a ground rod....
Good advice above.........
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 01-22-2013, 06:29 AM   #11
Thread killer
Good god, ddawg, you live in southern Cal, have you seen frost other than in your refrigerator?
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 01-22-2013, 08:30 AM   #12
gregzoll's Avatar
The OP area, they are showing low 30's for ground temps, so really not what I would consider frozen yet.
Old 01-22-2013, 08:39 AM   #13
This. I watched a tv show about lightning protection being installed in a house, and something like that was used for the ground rods. I couldn't believe how fast they went in. Literally less than a minute.
As a retired military generator guy, I've pounded in my fair share of ground rods by hand. It generally isn't much fun.
Old 01-22-2013, 10:29 AM   #14
Me Too!
Old 01-22-2013, 10:49 AM   #15
Use one of these on a jack hammer or large hammer drill. Let the tool do the hard work.
curiousB is offline   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
ttech (01-22-2013)
Multiple Ground Rods, help Ralph III Electrical 72 02-14-2012 10:31 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 07:34 PM
How to install a ceiling fan w/o a ground karebear09 Electrical 8 08-01-2011 08:48 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
