Install Electrical Outlet In Closet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 02:07 PM   #1
Install Electrical Outlet in Closet
I want to turn a closet in my living room into a media closet with an Amplifier, network and multiple game consoles. I do not have power in this area and want to add an electrical outlet. Is there any code violations that would be involved in this in the state of california?
cdmcali is offline   Reply With Quote
Old 08-21-2011, 02:12 PM   #2
Just call me Andrew
Rewards Points: 1,020
I think that's fine.
Andrew
secutanudu is offline   Reply With Quote
Old 08-21-2011, 02:34 PM   #3
I have been reading about the space would need the door removed. I do not want to do this. Are you familiar with this?
Old 08-21-2011, 02:34 PM   #4
Just call me Andrew
Nope...but let one of the experts chime in, they will.
Andrew
Old 08-21-2011, 02:39 PM   #5
I will wait to hear from an expert on here. Thank you
Old 08-21-2011, 02:44 PM   #6
Licensed electrician
Rewards Points: 1,054
Why would the door need to be removed because a receptacle was installed? Was this a ventilation issue due to heat from the electronics?
Old 08-21-2011, 02:50 PM   #7
I think what he means is - if you google "outlet in closet", some of the results are discussion boards in which they talk about certain AHJ prohibiting outlets in closets, so the homeowner took off the closet door making it a "storage area" instead, pleasing the inspector (the door was reattached after inspection). Not an issue if the OP's AHJ doesn't prohibit outlet in closet.
The bigger issue I think might be removing the heat generated by the gear in the closet :/
CuHead is offline   Reply With Quote
Old 08-21-2011, 03:14 PM   #8
I am going to install ventilation in the closet. That is not a concern of mine. I want to make sure that if for some reason something happens in the house and i need to do a insurance claim that they are not going to say "why you do that?" "that is not up to code."
Old 08-21-2011, 03:18 PM   #9
Honestly the only way to know for sure, is to ask the inspector. In my neck of the woods, I have to submit a detailed plan with the permit application, and the inspector will tell me immediately if something in the plan is not allowed.
Old 08-21-2011, 03:25 PM   #10
Off the topic a bit here. But since you mentioned the code. I'm not sure what you plan on having for lighting or if you are even changing it but the code does restrict where the fixture is placed and the distance from any shelving...
2008 NEC Article 410.16.
Bulbs required to be fully enclosed. Surface mounted only on ceiling or wall above door. Surface incandescents min. 12in from storage.
It goes on but I don't remember it entirely.
asfyxation is offline   Reply With Quote
Old 08-21-2011, 03:27 PM   #11
Not going to have any lighting in the closet. Not a huge space and I have a light right outside the door.
Old 08-21-2011, 05:41 PM   #12
Rewards Points: 6,652
Then you are good to go. Take into consideration how you are going to access the rear of the equipment and manage the wiring going to the equipment, oh and how much it will cost, because you will be surprised when you go to sit down and figure it all out, and what effect it will have, when you go to sell the house later on down the road, and the noise created by the cooling fans to help pull the heat out of that space.
Old 08-21-2011, 06:38 PM   #13
Master Electrician
Rewards Points: 3,698
There are no NEC restrictions for receptacles in closets. Local restrictions may apply.
brric is offline   Reply With Quote
Tags
closet , electrical outlet
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 05:38 PM
Bulhead Conceiled Electrical Outlet rayignacio Electrical 5 02-08-2009 03:52 PM
Above Ground Pool+Deck Electrical Install (Ontario, Canada) hecubus Electrical 5 08-02-2008 02:42 PM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 07:23 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 01:15 PM
