Install Electrical In Brick - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 03:24 PM   #1
Install Electrical in brick
Howdy,
I'm not new to electrical however I've never done what I'm trying to do. In our newly renovated basement I want to put an accent wall of full size brick. How do I install the outlets and switches if I don't want anything surface mounted? I am a very visual kind of guy so if you have some web sites or pictures I would appreciate it.
Thanks All ahead of time!
Lefte
Lefte is offline   Reply With Quote
Old 11-24-2012, 04:23 PM   #2
Licensed electrician
Rewards Points: 1,262
Install the conduit behind the brick with the face of the box flush with the brick.
Old 11-24-2012, 05:53 PM   #3
TTW
TTW's Avatar
Here ya go!
http://www.amazon.com/Arlington-DHB1.../dp/B004K1G11M
TTW is offline   Reply With Quote
Old 11-24-2012, 05:55 PM   #4
Too Short? Cut it Again!
Just curious. Are you building an actual brick wall? If not, why wouldn't use real brick veneers instead of solid brick?
Old 11-24-2012, 09:25 PM   #5
We renovated the entire basement. Actually removed the old brick basement and put in wood. I kept the brick to make it remain part of the house once we got to that point in the project. So yes SDSESTER, we are using full size chicago brick from circa 1890. Of course I have much more than I will ever need. What to do with the rest I wonder...
So it's an inside brick accent wall using full size brick. I'm starting to rouch in the wiring and want to have the right boxes and such in place.
I have the site photos here if you care to look:
http://mcnaughtonbasementrenovation.shutterfly.com/
Lefte
Old 11-24-2012, 09:36 PM   #6
Rochsolid's Avatar
Use masonry boxes for your receptacles and switches. Run your conduit in your brick up to the too of your wall. Will there be a dropped ceiling?
Rochsolid is offline   Reply With Quote
Old 11-25-2012, 11:31 AM   #7
I am thinking I'll run the cable through the stud wall to the box, with an extender to make the 3 inch wide brick. I am putting a drop ceiling on one side and drywall on the other.
Thanks everyone..
Lefte
Old 11-25-2012, 12:17 PM   #8
Rochsolid's Avatar
Originally Posted by Lefte
I am thinking I'll run the cavle through the stud wall to the box, with an extender to make the 3 inch wide brick. I am putting a drop ceiling on one side and drywall on the other.
Thanks everyone..
Lefte
If you use conduit, run it inside the brick and to a 90degree bend at the top of your wall so your EMT stub ends up in your dropped ceiling side
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Electrical Box In Brick (Interior) litleclay Electrical 3 09-12-2011 06:16 PM
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
Electrical oven install ctoph75 Electrical 12 07-11-2011 12:43 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
