Install Electric Range Top - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 12:23 PM   #1
JBH
install Electric range top
I am installing a new electric range top. The range has a red, black, white and bare (ground). The old range was connected to the wire under the cabinet that has Red, Black and Copper Shield Mesh Like. Is it correct to attach Red to Red, Black to Black and the White to the copper shield?
JBH is offline   Reply With Quote
Old 01-18-2009, 12:42 PM   #2
JBH
anyone know about this??
Old 01-18-2009, 12:58 PM   #3
You need a new line ran to your range top.
You need 4 wires at your range.
What amperage is your range?
rgsgww is offline   Reply With Quote
Old 01-18-2009, 01:02 PM   #4
JBH
I believe it is 30amp, the breakers are 40amp. I need to find the paperwork.
Old 01-18-2009, 02:42 PM   #5
Electrician
ctsmiths's Avatar
Rewards Points: 150
You'll need to run at least #8-3 with a ground if you have 40 amp breakers feeding.
ctsmiths is offline   Reply With Quote
Old 01-18-2009, 02:48 PM   #6
Post back sometime.
Is this what you have currently?
This is SER cable, and is not allowed. It was common among installations in the 70s-80s.
30 amp=10/3
40 amp=8/3
Old 01-18-2009, 03:33 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes you may connect to the existing cable. It is a seu type cable not ser and is allowed by code provided the branch circuit originates in the service equipment and not a sub-panel. You simply connect the bare and white of the new range top to the bare mesh of the supply.
You guys replying to JBH need to read NEC 250.140. and then google a cooktop (range top) and look at the installations instructions.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-18-2009, 05:32 PM   #8
Oh, I see now.
Help needed with finding the wires to install a range hood triginpgh Electrical 6 01-10-2009 02:09 PM
Range Install rsriverrat Electrical 8 12-28-2008 10:24 PM
gas or electric range? analogmusicman Appliances 8 09-25-2008 04:27 AM
Gas or electric range Josie Appliances 5 05-02-2007 03:23 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 05:03 PM
