Old 05-25-2011, 02:21 PM   #1
Install Contactor
Need to connect a Chint NC1 AC Contactor (NC1 - 1810) A float-switch in a water tank is 100m from the water pump. The float switch burns out after 6 months use. The float switch is connected to the L while the N is common directly to the pump motor and a power point. Have looked for a diagram on the net, but no luck. I'm not sure what goes where A1 - A2, L1 - L2 - L3 - 13 NO, T1 - T2 - T3 - 14 NO
Did upload a diagram - hope it shows
Flaxie is offline   Reply With Quote
Old 05-25-2011, 02:51 PM   #2
J. V.'s Avatar
Install Contactor
Have the float switch only open and close the contactor. Take L1 and N directly to the motor. The float switch is not rated for the motor current (amps). That is why it burns up.
Old 05-26-2011, 03:13 AM   #3
Install Contactor
Thanks JV, I can't get a float switch that is rated for the motor. Thats why I want to install the contactor, so the current runs through the contactor and not the float switch. If that makes any sense. Kind regards
Old 05-26-2011, 11:27 AM   #4
Install Contactor
Can anyone else help. Didn't get much response on the advise to install the contactor. Thanks
Old 05-26-2011, 11:52 AM   #5
Electrical Contractor
Install Contactor
A1 is the line from the switch.
A2 will be the neutral wire.
L1 will be the hot wire that feeds the switch, and T1 will be the hot wire that hits the pump.
The coil is 120 volts correct?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Flaxie (05-27-2011)
Old 05-26-2011, 12:19 PM   #6
J. V.'s Avatar
Install Contactor
I answered your question the first time. Lets be clear. The switch will open and close the contactor coil, not the motor.
The Following User Says Thank You to J. V. For This Useful Post:
Flaxie (05-27-2011)
Old 05-26-2011, 07:52 PM   #7
Install Contactor
Terminal names may be off, but this is how you want to do it
http://i.imgur.com/1wyOZ.jpg
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
Flaxie (05-27-2011)
Old 05-27-2011, 04:05 AM   #8
Install Contactor
Thank you Jbfan, worked perfectly. Tested it with a light fitting.
What a cool site. Many thanks
Contactor Replacement problem rickcusaf HVAC 19 06-08-2010 02:04 PM
contactor not pulling in????? help jeryfixit HVAC 7 03-30-2010 09:55 PM
contactor 'auxiliary contacts' "mix and match"? shag_carpet Electrical 5 02-05-2010 02:03 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
