Install 60 Amp Double Breaker With 6/2 Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 01:53 PM   #1
install 60 amp double breaker with 6/2 romex
I need to install a 60 amp double breaker using 6/2 Romex, my question is where does the black wire install on the double breaker, top or bottom of the breaker, normally the black is on top and the red wire is on bottom to complete the circuit, however, 6/2 Romex has only black, white and a ground wire, no red wire.
darthyogi is offline   Reply With Quote
Old 10-03-2010, 02:12 PM   #2
Master Electrician
Rewards Points: 3,918
It makes no difference. Reidentify the white wire with some tape or a marker.
brric is online now   Reply With Quote
Old 10-03-2010, 03:48 PM   #3
60 amp circuit breaker with 6/2 romex
Hi brric, when you said to reidenty the white wire(neutral) with tape or marker, do I connect the white wire to the bottom half of the double breaker? Thank you for the info.
Old 10-03-2010, 04:47 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
As brric stated, it makes no difference.
In your case the white is being used as a hot, NOT a neutral since this 240v circuit does not use a neutral.
What is this circuit for?
Old 10-03-2010, 08:56 PM   #5
u need to identify the white wire as a voltage carrying wire at all points that open at jboxes. And it dsont matter black up or down u could use red tape on the white wire.
Kirky is offline   Reply With Quote
Old 10-04-2010, 05:36 AM   #6
Rewards Points: 1,216
Good Question Petey ..yeah What is the circuit for?
COLDIRON is offline   Reply With Quote
Wire Length AFCI breaker install issue 205bhamjim Electrical 5 02-24-2010 02:33 PM
Wierd Double Pole Breaker Occurance rlemar Electrical 5 02-16-2010 09:43 PM
Double pole breaker v/s single pole breaker schultz56 Electrical 3 02-09-2010 01:12 PM
Double up wire on a breaker 83trekker Electrical 7 02-02-2010 06:51 PM
DIY Breaker Panel Install - Updated Photos jamiedolan Electrical 31 01-08-2009 01:39 AM
