Install 200A Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 09:56 AM   #1
Install 200A circuit breaker
As shown in the photo, there is no main switch and no outside switch. I want to install a 200A circuit breaker/main switch so that I can turn it off when I turn on the generator.
Does anyone know what kind of circuit breaker should I buy for this pannel and where online can I find one?
BTW, do I need to tell the power company when I unplug the meter for a short amount of time? That is the only way to disconnect from the grid.
Thanks,
Alex
alexbay0 is offline   Reply With Quote
Old 01-03-2013, 10:03 AM   #2
Licensed electrician
Rewards Points: 1,024
The first thing is that you do not have the training or protective equipment to pull a meter. It is also against the law in many areas.
You will need to check the panel label for a list of breakers that can be used in the panel. It may not be possible to add a main to that panel.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
HIVOLT (01-03-2013), NJMarine (01-03-2013)
Old 01-03-2013, 11:49 AM   #3
joed's Avatar
Rewards Points: 11,576
You need to tell more about the panel. It may not accept a main breaker. It could be a split bus panel and top half of the panel is consider the main even though it can have up to 6 breakers in it.
You need a proper transfer switch generator operation and it need to be permitted and inspected when installed.
The Following User Says Thank You to joed For This Useful Post:
micromind (01-04-2013)
Old 01-03-2013, 01:23 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Without knowing how much knowledge you have this is a beyond what most would consider DIY.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-03-2013, 02:44 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I agree with the others. I also get the impression that you are looking to backfeed from a generator without a transfer switch or interlock. This is a HUGE no-no.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 01-03-2013, 04:54 PM   #6
bubbler's Avatar
Rewards Points: 256
Definitely sounds like you're in the territory of paying an electrician $100 to come out, examine your setup and give a recommendation, would be a good idea.
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Old 01-03-2013, 04:59 PM   #7
Rewards Points: 282
My local POCO's proper protective equipment when pulling my 320a meter (400a service) is to pull the lever down then kind of look away and wince as you put the meter in or pull it out, lol.
jcrack_corn is offline   Reply With Quote
Old 01-15-2013, 11:42 AM   #8
Thanks,
Thanks everyone. Looks like I'd better hire an electrician to put in the main breaker.
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 10:14 PM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 09:17 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
