Install A 2 Pole Switch For A Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 01:10 PM   #1
install a 2 pole switch for a water heater
I installed a 30 amp switch so I could turn the water heater off when I didn't need it but the breaker trips when I flip it on. According to the instructions on the package I have wired it correctly. What would cause this. Kevin
rimshot is offline   Reply With Quote
Old 09-14-2010, 01:22 PM   #2
joed's Avatar
Rewards Points: 13,344
What would cause this is not having it wired correctly or a defective water heater.
Give us some details and maybe we can help.
Start by disconnecting the heater cable and see if the breaker still trips.
Old 09-14-2010, 02:35 PM   #3
Licensed electrician
Rewards Points: 1,774
I agree with Joed. Can you tell us the type of switch you bought; single pole, double pole,?
Old 09-14-2010, 04:02 PM   #4
liscenced electrician
Rewards Points: 538
you probably hooked the switch up wrong, so that the two hots connect together when you turn it on, creating a dead short
jimmy21 is offline   Reply With Quote
Old 09-14-2010, 06:21 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I am with others what type of switch it have and if you know the model number just post it here we will go from there and some disconnection switch it is too easy to transponed between the line and load connections.
That item I have see it pretty often when someone not pay attetion with it.
Merci.
Marc
Old 09-15-2010, 10:08 AM   #6
Licensed Pro
Wrong hookup or you have a 4-way switch instead of a 2-pole switch.
Is this water heater install legal? aoliver Off Topic 9 04-04-2010 05:30 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
DIY Install of Tankless Water Heater ManMythLegend Plumbing 7 12-21-2007 02:39 PM
