Old 12-06-2007, 04:20 PM   #1
Instaling An Outside Outlet
I LIVE IN A BRICK CAPE COD HOUSE WITH PLASTER WALLS. THERE IS ONLY ONE OUTSIDE PLUG IN MY ENTIRE YARD. HOW EASY IS IT TO INSTAL A OUTSIDE OUTLET? i WANN PUT UP CHRISTMAS LIGHTS AND THE ONLY OUTSIDE PLUGG IS IN THE BACK YARD. ANYONE HAVE ANY SUGGESTIONS? THANKS
JAVAMAN is offline   Reply With Quote
Old 12-06-2007, 04:31 PM   #2
nap
You talking to me?
nap's Avatar
do you have a basement, crawlspace, or slab foundation?
Old 12-06-2007, 04:33 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Flush mounted in the brick or just receptacles mounted to a short stem of conduit coming out of the ground?
Old 12-06-2007, 04:43 PM   #4
I Have A Basement And I Would Kinda Like The Flush Mounted On The Brick.
Old 12-06-2007, 04:47 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Ok so your wanting something like this?
Old 12-06-2007, 04:57 PM   #6
yeah that looks about right
Old 12-06-2007, 05:30 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Ok it requires proper location by that I mean you have to get a wire to the backside of the brick. That is just a matter of good measuring and finding the least amount of damage route getting there or the most amount of damage getting there but the easiest.....
You will have to make a series of drill holes using a good quailty mason 3/8" or so bit. And as you can tell you will need the proper template drawn on the brick. I like to use a tapcon bit about 1/8" first this will generally make a nicer cut out for the box if that doesnt work then enlarge with a 3/8 masonery.You may opt for just trying to take a whole brick out but be sure you have the correct clearance then you will just mortar the box back in. Anyway once the holes are bored in a rectangle you take a masonry chisel and using a hammer carefully remove the inner rectangle of brick. The rest is pretty self explanatory. It isn't going to look pretty at first but it all comes together in the end. Try not to be to perfect too small is worse than a little to large for the template.
Old 12-06-2007, 06:18 PM   #8
nap
You talking to me?
nap's Avatar
that particular box is an Arlington product.
Arlington's "InBox"
stubbie got you the hole in the wall but you need to get the wire up into the box. With a basement, that makes it a bit easier.
Do you know the structure of the wall? Wood framed, block, double or triple layered brick (some old old homes were built in this manner).
So, hopefully it is a wood framed wall. If so, when cutting in for the box, you may need to cut through the plywood sheathing as well (you will need a hole in it anyway). Measure from some reference point that you can use both in the basement and outside. Then, you will need to drill through the bottom plate of the wall directly under where you cut the hole in the brick. You should then be able to use a stiff wire (coat hanger) to poke from the bottom up (or vice versa). use this to pull the wire to the box cutout. Pull it into the box and mount the box to the wall and finish the install.
If the inner wall is CMU or brick, it changes the level of work.]
Let us know what the wall build is.
Old 12-10-2007, 08:28 AM   #9
the walls inside are plaster then a empty space with insulation then the brick. with i am guessing wooden studs, house was built in 1952 or 53
Old 12-10-2007, 11:39 PM   #10
nap
You talking to me?
nap's Avatar
if you have plaster on wood studs, that is about the easiest you can get. You should be able to access the sill plate and dril upwards and outwards sp as to get in to the call cavity or the cavity between the wall and the brick.
sounds like you are good to go.
any more questions?
Old 12-11-2007, 11:47 AM   #11
You might even be able to go straight through the rim joist in the basement if it is high enough above the outside grade level and avoid going through the sill plate altogether.
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
