The Inspector Says I Need A Switch.... - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 03:07 PM   #1
the Musigician
DangerMouse's Avatar
The inspector says I need a switch....
right next to the furnace....inches away from the switch INSIDE the furnace....
So here's a metal JB with 'flex' and clamps to shut off the furnace ("in case someone wants to put in a new furnace." he says) Of course, the way MY luck has been, I don't think it's correct.....so can anyone please tell me the right box, the right flex and the right clamps to use so I don't have to pay another $50.00 AND tear it all out and redo it again?
Thanks!
DM
Old 09-26-2010, 06:16 PM   #2
Chicago, IL
Michael Thomas's Avatar
Usually, the box is mounted on the furnace, over the knock-out to the interior.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-26-2010, 06:31 PM   #3
Rewards Points: 320
I would use a 4x4 with a close nipple in the knockout where that flex come out of. Use a raised 4x4 cover for the switch.
teamo is offline   Reply With Quote
Old 09-26-2010, 06:38 PM   #4
the Musigician
4x4 with a close nipple?
huh? Can you explain that in plain English so a dummy like me can understand?
DM
Old 09-26-2010, 06:50 PM   #5
Electrical Contractor
kbsparky's Avatar
I would utilize a 4x4 box with a chase nipple to connect to the unit:
The one shown can be purchased here.
-KB
Old 09-26-2010, 06:50 PM   #6
" Euro " electrician
frenchelectrican's Avatar
DM
I can rephrase what Teamo saying .,,
Grab a very short threaded half inch pipe and put two locknuts in the middle and one on each side after you put in the pipe in.
4X4 box mean it a common 4 inch square box and useally 1 5/8 inch deep and some have deeper verison.
For my side which I done very often just get a single gang metal switch box and take one KO out and put a box spacer or short nipplepipe like above and put a toggle switch and cover on it.
either way will work just fine and just give you a head up some states or proviances may reqired the cover to be painted red and some will say " Emeregcy shut off " one of few items will meet the requirement.
Merci.
Marc
Old 09-26-2010, 07:11 PM   #7
the Musigician
Is this any closer then?
He led me to think a plain old light switch is fine, is this wrong?
DM
Old 09-26-2010, 07:14 PM   #8
Yep that what we are talking about a switch outside of the furance { that why many area the codes required have a service switch outside of the furnace never inside of the unit.}
Merci.
Marc
Old 09-26-2010, 08:19 PM   #9
Chicago, IL
The box usually gets mounted flush to the furnace.
Also, you are not allowed to substitute water pipe and plumbing fittings for listed rigid electrical conduit and it's associated components.
Old 09-26-2010, 08:31 PM   #10
the Musigician
So then the first one is right?????
Color me lost once again....lol
DM
Old 09-26-2010, 09:36 PM   #11
fabrk8r
fabrk8r's Avatar
Michael Thomas meant "mounted flush on the furnace cabinet", using a chase nipple, as kbsparky said.
Take that 1/2" plumbing nipple out.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-26-2010, 10:45 PM   #12
Rewards Points: 1,192
Post #7 not an accecptable union.
Post #11 an acceptable installation.
bobelectric is offline   Reply With Quote
Old 09-27-2010, 08:58 AM   #13
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Odd I always thought the switch had to be away from the furnace. If the furnace is malfunctioning in a hazardous way, shooting sparks and about to blow up, the last thing you want to do is go CLOSER just so you can turn it off!
Old 09-27-2010, 09:07 AM   #14
Rewards Points: 150
DM, let me know if you need an "approved" switch cover. I bought 1 on e-bay, but they shipped my like 15. If memory serves me correct, it looks like one of these, but it says "Gas Burner", not oil.
TJ_in_IL is offline   Reply With Quote
Old 09-27-2010, 09:08 AM   #15
I have one switch at the furnace...on the furnace I think
I have a 2nd shut off switch at the top of the basement stairs
***Mine is an oil boiler & has the red plate
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
