#1 |
Inspector Said "1 hole, 1 cable, no exceptions"
During an inspection yesterday, an annoying "issue" cropped up in my electrical work.
The main thing the inspector said was that for any hole drilled in a framing member (joist, stud..etc), that there can only be 1 cable in each hole regardless of the size of the hole. As far as I can tell, this is NOT a code requirement, and the local rules don't have any amended sections indicated this to be required. Remedying this "problem" took me 11 hours yesterday, as I had to re-run almost every circuit, at least to some extent. Had I been aware of this "rule" I would have followed it, but as far as I can tell, no such rule actually exists in the NEC, and thus I had no way to be aware of it.My main irritation stems from the fact that I intentionally drilled 1" holes so that I could easily fit 2-3 14/2 or 12/2 cables through each hole, and not put 1,000 holes in my framing. Instead, I have now "swiss-cheezed" my joists and studs so that all the cables can run through. Can a licensed electrician chime in on this. This seemed like a pointless rule to follow, especially since I cannot seem to find any section of the code that supports this "1 hole, 1 cable" rule. Does such a rule exist in the 2008 NEC? These are the types of issues that make people not want to pull permits to do work. I have no issue making my house meet code, but forcing a homeowner to make senseless changes is ridiculous. However, I reserve the right to call myself an idiot if an NEC rule exists that does indeed state that only 1 cable can pass through a hole in framing.Anyway, I am hoping the re-inspection goes smooth today. Rant over ![]() Thanks. |
#2 |
Your inspector is nuts.
Ask him for this nonexistant code section when he shows up today. |
| The Following User Says Thank You to Code05 For This Useful Post: | Speedy Petey (09-27-2012) |
#3 |
Inspector Said "1 hole, 1 cable, no exceptions" |
#4 |
Lic Electrical Inspector
Unless it is a local requirement it is a bunch of bullshot!! Ask for the code section. Guys like this give us code officials a bad name.
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#5 |
And because of his incompetence, it cost you 11 hours of unnecessary work.
| The Following User Says Thank You to electures For This Useful Post: | Speedy Petey (09-27-2012) |
#6 |
That's the foggy "bundle" clause.
#7 |
After I "hopefully" get a pass today, I will ask him for the code section for the "1 hole, 1 cable" rule.
It probably does come down to the "bundle" section of the code, but if I am not mistaken, that talks about 5 cables in the same raceway and something about derating based on that, right? Yep, that was 11 hours I will never get back. I truly have never been more irritated in my life. |
#8 |
liscenced electrician
When I was an apprentice, one journeyman I worked with bored 2" holes all the way down tgi joists to the panel. Nearly every circuit In the house was run through these holes. The inspector called it bundling and made us change it. Other than that I've never heard of it being an issue. Though i don't do much residential
#9 |
Indeed. A little Googling turns up the following questions (among others).
Thread on another board Thread on yet another board For more, Google electrical wiring bundling code |
#10 |
" Euro " electrician
To OP.,
That is plain nuts and ask that inspector to show that rule in writing. I know there were nothing in NEC as far I know ditto with our French electrique codes as well. Only gotcha is bundling but that not really used on that part at all. There is two members which they posted above me they are correct on the answer there. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#11 | |
Inspector Said "1 hole, 1 cable, no exceptions"Quote:
Merci. Marc
#12 |
E2 Electrician
Since most framing is only 2x, it can never be considered bundled.... The only issue arises is when you are required to fire stop... then you could run into problems.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following 2 Users Say Thank You to stickboy1375 For This Useful Post: | frenchelectrican (09-27-2012), Speedy Petey (09-27-2012) |
#13 | |
Anyway, the good news is that my rough-in inspection passed today! |
#14 |
E2 Electrician
I would have corrected the inspector then weaken the structure with a thousand holes...
| The Following User Says Thank You to stickboy1375 For This Useful Post: | Code05 (09-27-2012) |
#15 | |
Licensed Electrical Cont.
Guys like this NEED to be called on this sh*t ALL the time. It is flat out unethical for them to request crap like this knowing folks will comply simply to not "rock the boat". I say capsize the boat!!
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| The Following 9 Users Say Thank You to Speedy Petey For This Useful Post: | Code05 (09-27-2012), electures (09-27-2012), Fix'n it (09-27-2012), frenchelectrican (09-27-2012), jbfan (09-28-2012), Jim Port (09-27-2012), kwikfishron (09-27-2012), mpoulton (09-27-2012), wirenut1110 (09-27-2012) |
| Display Modes | |
| Problem Patching Large Drywall Hole | FuLLTiLT | Drywall & Plaster | 5 | 11-21-2009 10:42 PM |
| what should I be careful about when drilling a hole through in the wall. | foxwood | Remodeling | 3 | 08-25-2008 05:17 PM |
| Allowed to run more than one romex cable through a single hole in a joist? | J187 | Electrical | 7 | 08-17-2007 09:46 AM |
| Coaxial Cable Question | bahaisamurai | Home Theater | 9 | 08-08-2007 03:54 PM |
