Inspection Question Regarding Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 04:17 PM   #1
Rewards Points: 129
Inspection question regarding cans
I will be installing new cans in an existing ceiling. The wiring is done on the arm of the fixture and then tucked up into the attic. How will an inspector want to see something like this when he can't check the wiring from the attic? Do you leave the fixture hanging out of the hole? There are 4 of them tied together.
wease is offline   Reply With Quote
Old 02-05-2011, 04:39 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I think the only person who can accurately answer this is the inspector.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
wease (02-06-2011)
Old 02-06-2011, 12:39 AM   #3
Registered User
Termite's Avatar
I'm not THE inspector, but I am AN inspector.
On remodel-type cans going into a ceiling that is already rocked and when there is limited or no access, I suggest that the best thing to do is wire them and leave them hanging from the ceiling so the inspector has the ability to inspect your wiring and connections if he wants to. He'll probably appreciate the gesture, and sticking them up in the ceiling after the inspection is quick and easy.
The Following User Says Thank You to Termite For This Useful Post:
wease (02-06-2011)
Old 02-06-2011, 08:21 AM   #4
Rewards Points: 129
Good idea. It is pretty easy to 'install' them. I'll leave them hang out a little so he can check them if he wants to. Thanks.
Inspection failure spiragui Roofing/Siding 2 07-07-2010 11:51 AM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 02:11 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
State Vehicle Inspection - ARGGH Leah Frances Off Topic 14 04-05-2008 12:59 PM
