Inspection Monday For Shop Electrical. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 08:36 PM   #31
Originally Posted by Newbomb View Post
There is a white stripe on the neutral.
Do you mean I need to use some (spray foam insulation?) sealant that seals up the conduit/wire where it comes into the panel.
Yes, GFCI's are first in line on all of the plugs circuits.
300.7 Raceways Exposed to Different Temperatures.
(A) Sealing. Where portions of a raceway or sleeve are known to be subjected to different temperatures, and where condensation is known to be a problem, as in cold storage areas of buildings or where passing from the interior to the exterior of a building, the raceway or sleeve shall be filled with an approved material to prevent the circulation of warm air to a colder section of the raceway or sleeve.
Semi-Retired El is offline   Reply With Quote
The Following User Says Thank You to Semi-Retired El For This Useful Post:
Newbomb (06-10-2012)
Electrical Inspection mike6679 Electrical 5 01-09-2010 11:35 AM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 12:56 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 06:52 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 03:32 PM
