Inspection Monday For Shop Electrical. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 01:56 PM   #16
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Originally Posted by Techy View Post
I'll give you the appears to be a sub in a detached, but the main breaker is *right there*
Oops- Now I see it. Ignore my last post.
Coastal South Carolina
Old 06-10-2012, 03:15 PM   #17
PUD said only three wires needed. It is fed straight from the xformer, 200A. Panel is a Siemens G2040B1200CU. M/B panel.
http://www.sea.siemens.com/us/intern...ad_Centers.pdf
Yes, I will put a plate in front of the conduit. Have also trimmed up the sheathing on the light switches.
Newbomb is offline   Reply With Quote
Old 06-10-2012, 03:17 PM   #18
Also, there is no meter at the detached shop. PUD is to put in a CT meter 150' away at the xformer.
Old 06-10-2012, 03:33 PM   #19
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Did you use anti oxidant grease on the wires and did you tighten the green bonding screw on the neutral bus?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-10-2012, 03:38 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Anti Oxidant isn't required, and with that said, I have never seen anyone install the product correctly to begin with.
Old 06-10-2012, 03:39 PM   #21
Yes, and Yes.
Old 06-10-2012, 03:47 PM   #22
I believe oxidant is required with 4/0 aluminum triplex on aluminum contacts. I put it on anyway. Scrubbed it on with a wire brush according to the directions.
Old 06-10-2012, 03:49 PM   #23
E2 Electrician
It certainly won't hurt anything thats for sure, and you might be the first person that ever read the directions. lol....
Old 06-10-2012, 05:05 PM   #24
Rewards Points: 3,256
I'm curious how far away your new shop is from your house or main service? Is there an added monthly fee for the extra meter?
zappa is offline   Reply With Quote
Old 06-10-2012, 05:30 PM   #25
You need some white tape on your neutral, unless a white stripe is where we can't see it. Also, need to seal the PVC conduit where it enters the panel from below grade.
Are all the 120V 15A & 20A branch circuits GFCI protected in the garage?
Semi-Retired El is offline   Reply With Quote
Old 06-10-2012, 06:37 PM   #26
The shop is 150' from the xformer -- in a different direction from the house, which is about 200' away.
The PUD wanted to charge $12/mo for an extra meter. So, I elected to have them remove the meter from the house, and meter at the xformer. They will install a single CT meter at the xformer, and I will not have the extra $12 charge per mo. However, they charge $400 to do this.
Old 06-10-2012, 06:41 PM   #27
There is a white stripe on the neutral.
Do you mean I need to use some (spray foam insulation?) sealant that seals up the conduit/wire where it comes into the panel.
Yes, GFCI's are first in line on all of the plugs circuits.
Old 06-10-2012, 06:52 PM   #28
Pure Genius
Rewards Points: 150
Ive never had an inspector make me seal an underground pipe but if i had to i would use a wad of duct seal found in the elec dept of lowes
Dierte is offline   Reply With Quote
Old 06-10-2012, 07:04 PM   #29
Good deal on the meter.
Had a friend smell something decaying in the basement. Turned out to be a dead snake in his breaker panel.
Old 06-10-2012, 07:28 PM   #30
rrolleston's Avatar
Ask the supply house for some duct seal. It's cheap and keeps moisture and critters out of the panel.
Electrical Inspection mike6679 Electrical 5 01-09-2010 11:35 AM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 12:56 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 06:52 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 03:32 PM
