Inspection Monday For Shop Electrical. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 07:23 PM   #1
Inspection Monday for shop electrical.
Anyone see things I may have missed? There is a lot more, but the panel is my main concern.
Inspection Monday for shop electrical.-20120609_140432-1024.jpg   Inspection Monday for shop electrical.-20120609_140440-1024.jpg   Inspection Monday for shop electrical.-20120609_140535-1024.jpg   Inspection Monday for shop electrical.-20120609_140634-1024.jpg
Newbomb is offline   Reply With Quote
Old 06-09-2012, 07:39 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It looks like your neutrals ang grounds are bonded. This is a sub panel right?
Old 06-09-2012, 07:42 PM   #3
k_buz's Avatar
Found your other post about the service. Ignorey above comment.
Old 06-09-2012, 07:43 PM   #4
Sparky
Rewards Points: 510
If it is a subpanel, it's only fed with 3 wires.
Techy is offline   Reply With Quote
Old 06-09-2012, 07:46 PM   #5
k_buz's Avatar
Switches aren't grounded and there is too much sheathing inside the boxes.
The Following User Says Thank You to k_buz For This Useful Post:
miky1948 (06-10-2012)
Old 06-09-2012, 08:01 PM   #6
Pure Genius
Rewards Points: 150
Looks like his switches are grounded. But around here we have to crimp our grounds instead of just nutting them
Dierte is offline   Reply With Quote
Old 06-09-2012, 08:06 PM   #7
k_buz's Avatar
Damn it...phone pic didn't show the ground to the switch...just saw the splice.
Old 06-09-2012, 08:08 PM   #8
Pure Genius
Rewards Points: 150
Switch on right took me a few looks to find the ground.
Old 06-09-2012, 11:33 PM   #9
I'll post a few more in a bit. Are you saying it will fail inspection with wire nuts on ground instead of crimps?
Old 06-09-2012, 11:35 PM   #10
Yes, I did leave a bit too much sheathing. But, is there code that says it should not be there? I just want to make sure it passes.
Old 06-09-2012, 11:39 PM   #11
Couple more.
Inspection Monday for shop electrical.-20120609_202556-1024.jpg   Inspection Monday for shop electrical.-20120609_202731-1024.jpg
Old 06-09-2012, 11:55 PM   #12
zpm
yeah, right
1/4" minimum. But leaving that much makes it much harder to work with and looks hack.
Also need to staple cables within 8" of boxes without internal clamps.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 06-10-2012, 12:22 PM   #13
miky1948
you will need to kick plate where you came thru stud with pvc
miky1948 is offline   Reply With Quote
Old 06-10-2012, 12:49 PM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
This appears to be a sub panel in a detached building and needs a 4 wire connection back to the supply panel. Also since tbere is no main breaker you can only have 6 handle throws in this panel. And it looks like you are set up for alot more.
I don't see how this install will pass.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-10-2012, 01:19 PM   #15
Sparky
Rewards Points: 510
I'll give you the appears to be a sub in a detached, but the main breaker is *right there*
Electrical Inspection mike6679 Electrical 5 01-09-2010 11:35 AM
Electrical Inspector Permitting problems zedman Electrical 27 11-27-2009 12:56 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 06:52 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 03:32 PM
