Inserting A New Breaker While The Panel Is Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2008, 01:17 PM   #1
Rewards Points: 1,062
Question
inserting a new breaker while the panel is hot
is it safe to insert a breaker in a slot while not switching the panel off but the breaker itself is off ?
Old 06-30-2008, 01:44 PM   #2
joed's Avatar
Rewards Points: 11,998
That is how I do it all the time.
Old 06-30-2008, 02:01 PM   #3
thank you sir.
Old 06-30-2008, 02:08 PM   #4
Registered User
Termite's Avatar
Not necessarily safe, but it is common practice. If done correctly there is basically no hazard. It is just safer for people that don't work as electricians every day to work in a panel with the main shut off. Just be careful not to touch the bus bar and be sure that the breaker is off when you roll it in.
Old 06-30-2008, 09:01 PM   #5
Electrician
Rewards Points: 778
Depends on who is asking the question.
A DIY with little knowledge of electricity i would say turn the breaker off and play it safe. One slip of your hand and you will be touching the bus bar.
A seasoned professional electrician, absoulety it is safe. Just like my fellow canadian i do it all the time as well.
darren is offline   Reply With Quote
Old 06-30-2008, 11:50 PM   #6
yeah, the canadians are so superb ! south of the border, we need to pay closer attention.
Old 06-30-2008, 11:56 PM   #7
Electrician
Rewards Points: 778
About time one of you admit it, now just to get the other 300 million on board
Old 07-01-2008, 12:11 AM   #8
Exclamation
yeah man, as soon as i start getting older and sicker, i'll be making my way up north.
Old 07-01-2008, 09:59 AM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I think it should be noted that there really is no reason to work in a panel that does'nt have the main deenergized. That said it is a common practice for 'roll in' type breakers to be installed with the main energized, however not all house panels have 'roll in' type breakers. Case in point... pushmatics of older vintage are bolt in...not one you would want to install with the panel energized.
Old 07-03-2008, 12:44 AM   #10
liscenced electrician
Rewards Points: 538
or in some zinsco panels you need to pull the meter since there is no main, and you can't get some of them out hot
but if we are talking a new cutler hammer of a seimens. don't worry about it, just be aware of what your doing
jimmy21 is offline   Reply With Quote
Old 07-03-2008, 11:21 AM   #11
For a modern panel, I don't think it's installing the breaker itself that is the issue. The real problem is bringing in the new cable, with it's exposed ground conductor. If that ground gets across the hot bus, and also touching the ground bus, you will have a very spectacular display of arc welding. The copper will melt, and fly all over the place.
If you are going to work live, I highly recommend wearing face (at least eye) protection.
I have done it both ways, and have gone back to working with the mains shut off.
FW
fw2007 is offline   Reply With Quote
Old 07-03-2008, 12:09 PM   #12
Rewards Points: 538
I also don't think thats a big deal. Just don't strip your romex until after its in the panel and just be aware of what your doing.
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 04:06 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
