Old 04-06-2012, 04:36 PM   #61
Licensed Electrician
k_buz's Avatar
Input needed on 240 vs. 120v situation
Originally Posted by mpoulton View Post
Whoa, there! Hold on a minute. This looks like a 3-wire feed, not 4. He can only separate neutral and ground if there is a separate grounding conductor back to the main. Otherwise this would be disastrous - the panel would be ungrounded. A 4-wire feed may not have been required at the time this was installed, in which case a 3-wire feed with neutral and ground bonded is perfectly acceptable.
While you are correct that I SHOULD have asked if the panel was fed with a metal conduit, a grounded conductor is not required to separate the grounds and neutral. It very well could be a 3 wire feed with the conduit supplying the ground path.
If the panel is is done in PVC with 3 wires, then the panel isn't grounded anyway (no bond screw from the neutral bar and the case) and we could debate which is more dangerous, bonding the neutral and ground or having no ground.
Judging by the age of that panel, a ground would be required. There is new(er) THHN's feeding the panel and romex thruout. I don't know when the code changed that required neutrals and ground not be bonded, but I know it was well before romex came along.
I'll ask the question now, how do the feeders arrive at the panel? Metal conduit or PVC?
Old 04-06-2012, 07:43 PM   #62
Semi-Pro Electro-Geek
Yeah, I missed that there's no bonding screw. Somebody just needs to go through this whole installation and make it better. There are multiple ways to do it, but it needs to be done.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
k_buz (04-06-2012)
Old 04-07-2012, 12:05 AM   #63
Probably not going to like this answer but the feeders run off of a 100amp breaker from the main box in the house underground through metal conduit into the barn. The metal conduit runs to the top of the rafters in the barn, ends, and than the feeder cables run along one of the rafters and down into the sub panel in the pool/workshop area.
I.E - the metal conduit stops after the feeder cables get to the rafters, than it's just the cables themselves (no conduit) going into the sub panel.
BigCoolJesus is offline   Reply With Quote
Old 04-07-2012, 12:14 AM   #64
k_buz's Avatar
Yeah, that doesn't sound good. Have an electrician come over and take a look at what you want for the A/V and fixing up the sub panel. He should be able to do that for free.
Old 04-07-2012, 12:29 AM   #65
Will do. Thanks for everyone having patience with me. The power is definitely there (no need to upgrade service).....just need to clean up that mess of a sub panel. Small investment to make sure it's done right is fine by me.
Old 04-07-2012, 01:33 PM   #66
Originally Posted by danpik View Post
My color blindness may be getting in the way but, is that a colored wire (black) on the neutral bar
That thick gray-ish wire that connects to the bottom of the busbar? I wonder if that's going to a grounding electrode somewhere. This is a detached structure, right?
fa_f3_20 is offline   Reply With Quote
Old 04-07-2012, 04:52 PM   #67
Average Joe/ex-Navy IC3
gregzoll's Avatar
I find it funny that something as simple as this would be over five pages. If the spec's on the product call for a 20 amp circuit at 240v, and a 15 amp circuit at 120v, go with what ever is easiest. It really does not matter which you choose, but if it was me and I did not want to do a bunch of rewiring, I would go with the simplest and that would be plugging it into a 120v/20 amp circuit and be done with it. No need to reinvent the wheel.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Reverse Polarity? 120v on coaxial cable shield dogdjour Electrical 8 10-11-2011 10:19 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-06-2011 12:43 AM
switch from 120v to 240v new breaker popwarfour Electrical 24 04-28-2011 09:17 PM
converting a compressor to run on 120v wizz1022 Electrical 1 05-04-2010 05:30 PM
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 12:29 PM
