Inoperable Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 04:27 PM   #1
Inoperable Outlet
Hello, I am looking for some help troubleshooting the electrical system in my home. Here is the situation. I plugged a treadmill into an outlet in my home, the treadmill worked for about twenty minutes then stopped. It has its own built in circuit breaker which I checked first. Then I checked the outlet. There is no power coming from the outlet, along with about three more outlets nearby. I went to the panel outside and checked all the breakers. None of them looked like they were off. I went ahead and sequentially turned off and on all the breakers. I did this about three times just to make sure. I went inside then and hunted down all the GFCI outlets I could find and tested and reset all of them with no luck. I was not sure which breaker went to this outlet, so I got a tester which transmits which outlet goes to which breaker. I started mapping all the electrical in my house, but realized if there is no power going to the outlet, then this will not tell me anything. Then I went and got a multimeter and tested all the circuit breakers, thinking one of them must be bad. I tested all of them, and all had approximately 120 volts.
This is where I am now. I do not know what to do next. I can’t really afford
right now to call an electrician, but if that is my only option I guess I will have to.
Can anyone tell me what to do next, or maybe what I have missed so far?
Godzilla is offline   Reply With Quote
Old 07-08-2012, 06:33 PM   #2
The high treadmill current draw caused a marginal connection to fail to a completely open connection.
If you know in what order the outlets are wired you have a better chance of finding the open.
Another way is to put a turned-on lamp in the treadmill socket and have someone watch it while you push on each dead outlet. This assumes there is only one open connection and that is almost certainly a good assumption.
Old 07-08-2012, 06:37 PM   #3
MarginallyQualified
Rewards Points: 2,464
^^This.
In plain English it means to open the first NON working receptacle box in the series and the one immediately before that one.
The "marginal connection" you're looking for is a loose screw, loose wirenut (my guess) or a dislodged wire from the back stab holes.
hth
Old 07-08-2012, 08:00 PM   #4
Thanks, I will open the outlet cover and check it out. I figured the treadmill is a heavy load. During all of this I got out the manual for it, and it says to have a dedicated single outlet surge protector, which I didn't have on it.
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 06:37 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
