Inline Bath Fan For 2 Bathrooms, Powered Dampers - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 05:11 PM   #1
Inline bath fan for 2 bathrooms, powered dampers
OK, here is the thread that I kind of hijacked and then decided to leave alone, because it seems the OP was satisfied... Wiring inline bath fan for multiple bathrooms
I have purchased the parts, discussed the wiring with an electrician acquaintance (it's his job, so I feel wrong about asking him for more help, without paying. He gave me 30 minutes in the middle of the day already. If he were on this forum, then that would be different, as you folks like to help and give freely) and he helped me come up with a solution using relays. I think I have it all figured out, and want to make sure and share with those who want to attempt the same endeavor.
Basically the cat I am trying to skin is the same/similar one as the thread: One fan, in the attic serving two bathrooms; two powered dampers (don't want one bath getting ventilated if not requested); timers in each bathroom to start/stop the fan. I could go with 3-way timers, but getting the damper powered separate is the problem. So, the electrician suggested relays. I think I have the correct ones. See the diagram below and please give me any thoughts or suggestions on ways to proceed. Thanks In Advance (TIA)
jdanw is offline   Reply With Quote
Old 08-24-2012, 10:05 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Why install the dampers? why make this so much more complicated then it needs to be? Install a fan in the attic, and install a switch in each bath room to turn the fan on... done.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (08-24-2012)
Old 08-24-2012, 10:13 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I agree with Stick. No reason for dampers.
FanTec makes a kit all set up for this.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (08-24-2012)
Old 08-24-2012, 10:40 PM   #4
Don't want both baths ventilated if not requested by the occupant of each bathroom, hence the dampers to allow flow...
Old 08-25-2012, 09:43 AM   #5
E2 Electrician
Buy two fans, less complicated and probably cheaper in the end.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
andrew79 (08-25-2012), Speedy Petey (08-25-2012)
Old 08-25-2012, 11:11 AM   #6
OK...I already have all of the equipment and parts. I just want to make what I have work.
Old 08-25-2012, 11:15 AM   #7
Rewards Points: 12,840
Or just one fan and two inlets, one output.
http://www.ventingdirect.com/panason...6-duct/p531512
Wiring inline bath fan for multiple bathrooms secutanudu Electrical 27 08-24-2012 03:38 PM
Inline Bath Vent Switch Wiring Dano81 Electrical 3 05-09-2012 11:52 PM
Inline exhaust design ideas with dampers (pics) picflight HVAC 7 09-13-2011 11:27 AM
Browse New Generation Bathrooms Design & styles bathroomsuk Plumbing 0 09-20-2010 02:38 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
